General TR Head Gasket Test Fit
RJS
Hi
At the risk of asking a dumb question, here goes. This is my first time replacing a head gasket. I test fit the gasket over the head studs. Everything lines up great with the exception that the four holes at the corners bind slightly on the corner head studs. This causes the gasket to lift slightly in the center and I am unable to get it to lie flat on its own.
Is this OK and will the torque of the head nuts simply compress everything into place? Or, is it safe/better to round out those holes in the gasket to allow it to lay flat (I am concerned this would compromise the gasket in other ways).
Sorry for what may be a dumb question but I'd hate to have gone through all this and make such a novice mistake. Many guides tell you to test fit but they don't tell you what to look for.
Thanks
Bob
PS: do you recommend anti seize on the stud threads which go in the block. I wasn't going to
CJD
It will flatten when the head goes on! It should not be a problem unless you think it is bowing so much that it would bend as the head pushes it...But I can't imagine it being off that much. If it gets in the way during the assembly, you can always carve a little material off the side of those 4 holes, so the gasket will lay flat. Just be sure to take equal amounts from each, so the location remains the same.
I use anti seize on all studs. The only exception is if it is a stud that I plan to disassemble a lot...like say the head stud on a race car. In that case I use loctite, so the stud stays in place during quick head changes.
RJS
RJS
Thanks John,
Appreciate the info. I spoke to the supplier yesterday who basically told me exactly the same thing.
So I plan to "Keep calm and carry on".
Bob
Brinkerhoff
You test fit to make sure the head gasket leaves all the coolant holes open so you know you installed it "right side up". As long as both mating surfaces are clean and flat you sound as if you are working carefully enough ! I use Anti- Seize on all studs , etc. but I tighten the block studs a bit so I'm sure they are in the block the entire way and won't unscrew when you re-torque the head.
malbaby
Not all head gaskets are made correctly.
As well as the above comments, make sure that there is no intrusion of the gasket into the combustion chamber.
RJS
RJS
There is no intrusion into the combustion chamber. I have 87mm liners & pistons and this gasket is for a big bore 87-90mm set up. It looked perfect on set up.
Oddly however, the gasket that came off (installed by PO) was for the stock 86mm liners/pistons and I could definitely tell there was 1mm hanging in the combustion chamber.
For years I had a crankcase pressurization problem. I always thought it may be worn rings but, maybe that was it. We'll see once I get this back up and running.
Bob
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
DrEntropy MGB Head gasket R&R goes on... MG 13
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
R BJ8 Cylinder Head Gasket Austin Healey 38
B TR4/4A Head gasket won't lay flat Triumph 13
Michael Oritt Head gasket question Austin Healey 17
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
Simmo TR2/3/3A Head Gasket Triumph 4
KVH General Tech Head Gasket Triumph 10
D TR2/3/3A head gasket... which way up?! Triumph 8
KVH TR4/4A Blown Head Gasket? Triumph 12
T TR4/4A Head gasket sealer question Triumph 7
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
H TR4/4A Head Gasket Issue Triumph 4
Got_All_4 TR2/3/3A What direction does the head gasket go? Triumph 4
T TR4/4A Best head gasket for a 4A? Triumph 12
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
B Victoria British Head Gasket Austin Healey 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
G Payen XK engine head gasket -- which side is the top? Jaguar 2
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
S Tolerance for head gasket Austin Healey 10
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
Gliderman8 TR6 Question on installing new head gasket Triumph 2
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
B Experience with Cometic Head Gasket for BN2? Austin Healey 8
S SaxMan's Cylinder Head Overhaul / Head Gasket Replacement Thread Spridgets 135
M TR2/3/3A Head gasket leaking in two places Triumph 13
S TR2/3/3A head gasket Triumph 5
AngliaGT General MG MGB GT Head Gasket - What do I need? MG 3
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
O HEALEY 100 Head Gasket Gone ? Austin Healey 10
