Tolerance for head gasket
Susan Lybolt
Member
New rebuilt over heated. I have .02 on the head and .02 also on the block. Do I need to machine the head before refitting the head gasket?
Legal Bill
I assume you measured this with a straight edge and a feeler gauge? .02 is 20 thousandths. What I am reading is that combined you have a 40 thousandths gap between head and block. Is that correct? I'm pretty sure the head gasket cannot tolerate a .02 gap. I'm positive it cannot tolerate a .04 gap.
Keoke
0.02 Hmmm
Weren't the surfaces machined as part of the rebuild ??
Keoke
They were good until I used the wrong radiator cap. Short stem, lost antifreeze. Temp off the gage. You could say I red lined it.
Well the simplest thing to do is resurface the head.
CraigC
Susan can you confirm that both the block and head are 0.020" out of flat or did you mean 0.002" ?
At 0.002" you cou​ld assemble as is.
If you really are 0.020" out, the block will require decking at a minimum. More importantly it should be checked in EVERY dimension to make sure cylinders aren't out of round and the block is not twisted.
If you severely overheated, good chance your rings are done. Reusing them may result in excessive oil consumption and/or blowby.
I would not recommend surfacing the head to eliminate 0.020" of bowing. You will end up with additional problems such as differences in combustion chamber volume that will raise compression in cylinders where the most material is removed. There are specialist companies that "might" be able to straighten that successfully.
Do it correctly now. You will be better off in the long run.
S
Susan Lybolt
Member
The head and block were measured with a levelometer and feeler gauge. They were .002 in different areas of the head and block. not .02.
Keoke
I figured that was the case as at 40 thousandths there would have been no argument.
Still the simplest thing to do is resurface the head.
vette
Susan, get a hold of some of the companies that actually make head gaskets. There are many American performance car companies that might have a pattern for the Healey. They make many types of gaskets that can compensate for irregularities. I don't think .002" is too much to compensate for. Dave.
W Brake Drum Tolerance ? Austin Healey 2
CCURTISS Wheel True - Tolerance Specification Restoration & Tools 1
M Tiny Tears in Top Test Tim's Tolerance Spridgets 5
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
