General Tech ARP Head Studs/Liner Protrusion
KVH
I have two issues: First, my ARP stud lengths do not match the Shop Manual specs. Nine of ten match, but there is no 5 5/8" stud for the front passenger position. It's 5 1/2 inches. Any big deal?
Second, two of my new liners (County Brand) are proud of the block by .007, and spec is .003 to .005. I'm inclined to believe a good sandwich head gasket will address the issue. I'm not inclined to pound them out and go through some kind of return routine. I once actually measured the thickness of the "figure 8" gaskets and found the copper ones .001 thicker than the aluminum ones. I probably should've used the aluminum ones--since they were in the kit. But I remember seeing aluminum ones all chewed up and corroded on a rebuild years ago and opted for copper.
I'm curious if others have addressed a similar issue and whether I'm likely right about the gasket forgiveness. And what's with ARP? Is that a mistake or do they figure an "eighth" of an inch doesn't matter?
Postscript: I just "mic'd" the aluminum figure eights. And then rechecked and corrected my readings. They measure .0157. The copper measure .0189. That's right about .003 difference. I guess I messed up using the copper ones but I'm surprised despite my last experience that there's some deliberate sizing going on there. It "sort of" tells me that a .003 variance isn't a problem so long as the variance is proud. It's as if the gasket set makers must make assumptions, and they assume thicker--safer for a fit. I'm actually puzzled.
Any thoughts?
Popeye
Bronze
I’ll let smarter folks answer the Fo8 gasket questions…
Yes, the ARP stud lengths do not match the manual. The difference is small enough not to be an issue.
KVH
KVH
I chickened out. I pulled the sleeves and replaced the figure 8s. I had two measurements at almost .008 proud with copper and couldn’t sleep.
Now I have another question. Am I supposed to have the pistons face a certain direction? I ask because each of my new pistons has a blue dot on one side of the wrist pin. Is this telling me that the blue dot faces forward or backward? I guess I should ask the same question with regard to the number “stampings” on the top of each piston. Is there some logic there, meaning that the stamping faces toward the camshaft or away from the camshaft?
Graham H
Are you confident there is no gasket or scale left in the block that is giving you a high sleeve height reading?
Graham
CJD
That is common with F08's. In the "old days", I am sure you had enough options to find the perfect thickness f08's to get the perfect liner height. Now we are stuck with one copper and one steel option...unless someone overseas has more options. By all means, use the one that gives you the best liner height. If the height is too high with the steel, then you have to have the top of the liners shaved into range. I am sure the head gasket would allow a few thousandths extra protrusion, it's just too easy to correct when the engine is apart. I have been using Wellseal on the F08's and the head gasket. If Rolls used it on the Merlins, that's reason enough for me!?!
KVH
KVH
What’s surprised me were the measurements I took late yesterday. If the copper gaskets automatically guarantee .003 greater protrusion, anyone would be quickly out of spec with gaskets and liners already perfectly measured to be within spec— particularly at the high end.
In my case, it appeared I was .003 above spec and I wasn’t confident that was acceptable even with the extra protection of a head gasket. In the end, as you’ve said, it’s easier to fix when everything is apart. No one would ever know in a case like this, but my “guess“ is that it would never have been a problem.
charleyf
Your initial comments stated one set of Fo8 were aluminum. I do believe they are steel. So the difference between the compression of steel and copper is what is at hand. I would suggest that they should both end up with the same compressed values. I have used both types without a problem.
Charley
KVH
KVH
I think copper might compress a bit, but that’s a bit of an exercise to prove, and I was way high. in retrospect, I probably could’ve just left the copper in and relied on the head gasket and compression to solve the problem. I just re-measured the steel ones, however, and they really are about perfect now. Every liner seems to be about .005 protrusion. My concern with what I ultimately did, using the steel F 8s, would be if the steel might rust and leak over time.
Sarastro
Yes, I've been through all this:
One thing I found: there are irregularities in the gaskets, caused by variable thickness, burrs on the edges, and lack of perfect flatness. You will get the calculated protrusion ONLY if the gaskets are perfectly flat, which is difficult to achieve. In the second of the above links, you can see what I did to flatten the gaskets--it wasn't difficult and helped a lot. In that case, the block had been shaved, so the numbers worked out better. I found that the sealer added no more than a mil or so to the protrusion, as long as the cylinders were well seated.
The gaskets will not compress to any measurable degree, but they will flatten out. Use plenty of sealer and tap the cylinders well into place with a hammer and wood block. Then, use bolts and large washers in the stud holes to prevent them from working their way out.
Like John, I question how critical this really is. A mil or two extra probably won't matter--but I'd err on the high side, not the low.
CJD
If you use wellseal or other sealant, only the edge of the steel will be exposed to coolant. It would take several engine lifetimes for the gasket to rust through. In other words...it won't be a problem using the steel. Plus, steel was the original and only option for the first many years of production.
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 1
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
T TR4/4A Are the ARP head studs worth it? [ducks for cover] Triumph 19
R ARP head and connection rod studs? Spridgets 15
M ARP head studs Triumph 5
martx-5 ARP Head Studs Triumph 21
Morris ARP Head studs torque... Spridgets 2
ChrisS ARP Head Studs Racing 2
RJS TR4/4A ARP Head Stud Question Triumph 2
hondo402000 TR6 TR6 ARP head bolts Triumph 4
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
D ARP big end bolts. Spridgets 7
G TR4/4A ARP Bolt Torque Specs Triumph 10
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
T TR2/3/3A ARP connecting rod bolts Triumph 2
RedTR3 TR2/3/3A Moss [ARP] Flywheel Bolts Triumph 16
F Using 12 point ARP style rod and main bolts Spridgets 9
hondo402000 TR6 TR6, 71 model flywheel bolts, ARP Triumph 2
S I just bought ARP main stud kit 206-5405 Austin Healey 4
L ARP fastners. Spridgets 4
Basil ARP studs too short Triumph 18
DNK ARP Studs Triumph 74
Glen_B Torque for ARP mains Spridgets 1
G ARP Assembly Lubricant....how to use the stuff Triumph 9
Morris ARP studs torque and blown headgasket Spridgets 17
7 ARP bolt kits Triumph 2
A ARP flywheel bolts--install Latest [no Loctite] Triumph 11
healeyboz ARP bolts Spridgets 6
healeyboz ARP bolts Spridgets 5
ChrisS ARP Rod Bolts Spridgets 7
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
