ARP studs torque and blown headgasket
Morris
As I recall, when I was torquing my ARP studs to ARP specifications, the torque was way less than factory spec. If memory serves... ARP called for 37 ft-lbs, and the manual wants 46 ft-lbs.
Could this have caused my head gasket to blow?
Downloaded the ARP catalog and read a few tech articles. It seems that torque is not my problem. Oh well. So much for simple solutions.
Morris
Don't forget the instructions (three times & lube).
Pat
I am pretty sure I followed the instructions to the Tee. But I guess we will find out when I get it all a apart... AGAIN!
Join the club, I share your pain.
Hey... at least I am in real good company, Jack! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
The best is when I try to out-think the professionals. I thought that the torque specs from arp were a little low. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif So I torqued to 40 lbs. So far so good. dunno
the reason for the diferent torque requirements are the LUBRICANT.
The factory torque figures are for motor oil lubricant use.
The ARP figures are for use with the lube they supply with the parts.( high MOS 2 grease).
Use the lube on ALL the threds..studs and nut threads. Also on the washer faces of the nuts and hardened washers. Do NOT exceed the torque figures bu more than 2%. it helps if you have a very accurate torque wrench.
It helps if the case deck and cyl head faces are smoother. Clean the decks with MEK or Acetone. Torque to 20# then go round in 5# increments till you get to where U want to go. Let the motor cycle twice hot to cold then re torque and reset the valves.
I've argued until I was blue in the face with ARP tech advisors, I absolutely refuse to use thier lower torque spec with their assembly lube, on rod bolts and head stud kits, that last time I talked to them, they admitted it really doesn't matter if you use original torque specs or thier reduced torque specs, I still use motor oil and on the head kits, and torque to 50 ft lbs, never, read that again, NEVER blown a head gasket, even on 15 to 1 1275 race motors and 16 to 1 948 race motors. Like I told ARP, why in the world would I ever alter something that has worked so well for so long for me. ON the rod bolt kits I go with their 50 ft. lbs on the 1275 rod bolts, I only use the proper 206-6001 rod bolts, and never had a problem there as well, in fact in the 1275 rod bolts instruction sheet it used to offer a lower torque value years ago with thier assembly lube, but with constant annoyance form builder like me, this is now dropped form the 206-6001 rod bolts instruction sheets. Now if we could just get them to lose the AMC rod bolt head on the MGB application and go with the proper chamfered edge design!!!!!! Sorry I'm not taking advice from some non engine building desk jockey tech guy when it come to my engines!!!!!
I just learned something again guys, thanks.
Oil on bolts that are being torqued.
When I replaced the head on my 1275 the "powers that be" (the people at the parts shop) said don't use any lubricant on anything - Improper torque reading was the reasoning... So I didn't...
Was I wrong not to use any lube?
Were they wrong?
cd
Now you tell me Jeff. What else have you not told us. LOL
Good info Hap. Thanks.
Do you think it's worth trying to re-torque before pulling the head?
I must say here that torque readings are given by the manufacturer to do several things. First anf formost, to provide a force holding the machine parts together with the necessary pressure. Secondly, the bolts are dimensioned to hold to the necessary and dimensioned force. The thread angle - incline - along with the diameter of the threads determine a ratio of torque to normal force.
Friction on the threads is calculated in with the necessary torque. (Friction between two steel surfaces is well known) A lubricated surface between the threads of the shaft and nut reduce the friction causing a greater normal force for the given torque. If the manual says dry threads, that's what they mean. They have dimensioned the torque reading for dry threads.
As I said, lubricating the threads gives more normal force for the same torque. If you give the spedified torque with lubricated threads, you are moving the bolt / stud further up the elastic area, and closer to the plastic area. This means permanent deformation (elongation) of the bolt / stud. In extreme cases, it can pass the deformation area and enter the break area, where the bolt / stud breaks. Extreme cases come quicker when there is less materal to elongate - short bolts.
Personally I wonder about the statement that ARP wants 37 while the manual says 46 lb*ft. Is this because the ARP bolts / studs are of a finer thread? If they are, this would give the same normal force as the courser thread at higher torque. On this point I agree with JerryB, follow the manufacturers recommendation.
Then comes the question of "WHY use ARP fasteners" if you are only going to achieve the same normal force. I thought the idea of using a stronger steel was to have a greater margin and the ability to use a greater stress within the elastic area. On ths point I agree with Hap. Use the steel properties you have available. Tighten the head at least as tight and maybe tighter than the factory suggested. As long as you don't crush the head (I've seen this on a Chevy 230-6) The higher torque provides a higher pressure on the head gasket and will help prevent leaks.
Donn, the reason ARP states lower torque value when using their assembvly lube is in their words "it creates less friction so thereforth require less torque". I think you'll find most racer do exactly as i do, oil threads and 50-52 foot pounds of torque, I normally start out at 50, then on re torques get an additional pound, it's worked for me.
Morris retorqueing is worth a try. If you end up pulling the head you may want to straight edge check both the block and head surfaces to rule them out as being a problem. Morris what head gasket did you use? and did you dress it with anything, the black composite (on both side) head gasket doesn't really require any dressing, but I still dress them, I used to use copper spray years ago, but I now use Permatex Hi Tack spray, no matter what head gasket I'm using.
Many years ago I was working at a heavy macine shop.
we were replacing the transmission deck on a hugh track dozer I was on one side with just plain old motor oil and a torque wrench Bob otheside with a tube of moly. Bob snapped off 4 bolts. The torque wrench went in to be calibrated hmmm. May be I was right after all these years. mind you these were 1"7/8 1 3/4 using a 4X wrench when those poped they ricocheted around the shop like gun fire SCarry!!
Well I re-torqued to 50#s and that seems to have fixed the problem... for now. Compression has come back up to 165#s on all 4 (was 145-155 before).
This will officially be the first time that the "easy fix" worked for me. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
And when the "easy fix" craps out on me next week. I have a head gasket on the shelf ready to go. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Morris ARP Head studs torque... Spridgets 2
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
T TR4/4A Are the ARP head studs worth it? [ducks for cover] Triumph 19
R ARP head and connection rod studs? Spridgets 15
M ARP head studs Triumph 5
Basil ARP studs too short Triumph 18
DNK ARP Studs Triumph 74
martx-5 ARP Head Studs Triumph 21
ChrisS ARP Head Studs Racing 2
D ARP big end bolts. Spridgets 7
RJS TR4/4A ARP Head Stud Question Triumph 2
G TR4/4A ARP Bolt Torque Specs Triumph 10
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
T TR2/3/3A ARP connecting rod bolts Triumph 2
RedTR3 TR2/3/3A Moss [ARP] Flywheel Bolts Triumph 16
F Using 12 point ARP style rod and main bolts Spridgets 9
hondo402000 TR6 TR6, 71 model flywheel bolts, ARP Triumph 2
hondo402000 TR6 TR6 ARP head bolts Triumph 4
S I just bought ARP main stud kit 206-5405 Austin Healey 4
L ARP fastners. Spridgets 4
Glen_B Torque for ARP mains Spridgets 1
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
G ARP Assembly Lubricant....how to use the stuff Triumph 9
7 ARP bolt kits Triumph 2
A ARP flywheel bolts--install Latest [no Loctite] Triumph 11
healeyboz ARP bolts Spridgets 6
healeyboz ARP bolts Spridgets 5
ChrisS ARP Rod Bolts Spridgets 7
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
K TR6 TR 6 Wheel Studs Triumph 10
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
Bayless How to repair broken vent window studs? Spridgets 1
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
Lin Water Pump torque value for nuts on studs Austin Healey 1
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
D TR2/3/3A manifold studs..locktite or antiseize Triumph 5
K For Sale TR3 Hub...short studs Triumph Classifieds 0
D TR2/3/3A More small nuts [ and studs!] Triumph 2
W TR2/3/3A TR3 wheel studs Triumph 4
af3683 TR2/3/3A Distributor Clamping Plate Studs Triumph 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
K TR2/3/3A Longer wheel studs? Triumph 5
