TR4/4A ARP Bolt Torque Specs
ghawk16
OK...I'm planning to call TSI tomorrow to see if they have the torque specs for the kits they sell for ARP main, rod and flywheel bolts for my TR4 but figured I'd ask here first to see if anyone knew or had some feedback. I know, I know...I'm sure the bolts are overkill for the TRactor engine but I figured why not while I was in there. But does anyone know if the torque specs change on the flywheel, main bearing caps and rod bolts when using ARP products. I'm sure the cylinder head kit will come with torque specs since it was made for the TR4 and listed on ARP's site. Thanks
Sarastro
I don't think it's overkill--there was a recent posting in the MG forum where a newly rebuilt engine was destroyed because a bolt for a rod-bearing cap broke. I think that using the best bolts you can get is wise.
Wouldn't they have the same torque as the ordinary ones? I'm having trouble imagining why they should be different, but maybe I'm missing something.
TomMull
G
ghawk16
If they are "stretch" design, they may be torqued differently. This might help:
https://arp-bolts.com/p/instructions.php
Yeah...I saw that Tom, but the problem is these bolts for the flywheel, rods and mains aren't a "kit" for the TR4. They are part numbers that TSI put together that fit the TR4. So I'm sure they did their research and found out the torque values. The head "kit" that ARP sells I'm sure will have the torque values in them as a lot more people of have used those. I'll give TSI a call shortly.
Sarastro
Hmmm...just as an example, I took a look at the ARP head studs, and they recommend 110 lb-ft. The shop manual spec is 100-105, which is, for all practical purposes, the same. My thinking was that the ARP bolts have greater tensile strength, but the amount of stretch for a given loading depends on diameter and elasticity, which should be virtually the same.
Best to contact the people selling them, of course. It would be nice if ARP produced a set specifically for TR4/4A rods and mains, and supported it with the kind of instructions they provide for their other sets.
Mickey Richaud
I just received rod, main, and head studs and bolts from ARP for the MGB engine I'm building, and they provide all info for torque specs and how to fit them with each set they sell. They also sent me a catalog and tech guide for all their current products. You can also go online or call and ask questions about any of their items. Great support.
G
ghawk16
Yep I called ARP on Friday and the customer support was awesome. And...you can buy directly from them which is nice. I got my flywheel bolts and main bolts and washers using TSI part numbers from Summit Racing and then ordered the rod bolts straight from ARP. Now after talking to support this is what they said and hope this helps in the future.
Bolts/Stock Torque/ARP Torque:
Flywheel Bolts (#206-2802)/42-46 ft lbs/55 ft lbs (so close enough...and ARP said it wouldn't even hurt to go with the stock value or go somewhere like 50 ft lbs as it's so close)
Rod Bolts (#4AP1.850-2U)/55-60 ft lbs/75 ft lbs (recommended looking at stretch after torquing using a rod dial gauge and they should go to about 3.5-4 thousandths)
Main Bolts/Washers (#HAR3.500-5)/85-90 ft lbs/100 ft lbs (ARP said 90 ft lbs would be perfectly fine with these since they are main bolts)
Head Stud Kit/100-105 ft lbs/110 ft lbs (Follow ARP torque values)
Be curious to see the difference in torque values on Mickey's MGB kits since the only "kit" for the TR4 is for the head.
Mickey Richaud
All my stuff is at the machine shop at present; not sure when they'll finish up, but will check back in when I get everything back.
G
ghawk16
So called ARP back and sure enough the torque values are wet values utilizing their lubricant. Also, for the main bolts the washers must be used due to length. So I asked ARP if this was OK and they said that the 200-8533 washers were OK to use with them. So...give them a shot and see what happens!
TBU_Triumph
Member
A few basics to remember with bolts and torque.
1) Torque is an approximate way to measure tensile load (stretch) in the bolt.
2) All bolts of the same size stretch at the same rate up to the elastic limit (strength) of that bolt.
3) The primary difference between the stock bolts and ARP bolts is that the elastic limit of the ARP bolts is higher. They will stretch further without permanent deformation.
4) The key limit is what the overall joint can handle. That is why the torque for the ARP bolts is essentially the same as the stock bolts. For example, the internal threads in the crank flange cannot take a higher tensile load just because the flywheel bolt is stronger.
So when you torque an ARP bolt to a given torque and a stock bolt to the same value you have the same clamp load. The difference is that if some load tries to separate the joint the ARP bolt will stretch further without failing.
7 ARP bolt kits Triumph 2
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
D ARP big end bolts. Spridgets 7
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
RJS TR4/4A ARP Head Stud Question Triumph 2
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
T TR4/4A Are the ARP head studs worth it? [ducks for cover] Triumph 19
T TR2/3/3A ARP connecting rod bolts Triumph 2
RedTR3 TR2/3/3A Moss [ARP] Flywheel Bolts Triumph 16
F Using 12 point ARP style rod and main bolts Spridgets 9
R ARP head and connection rod studs? Spridgets 15
hondo402000 TR6 TR6, 71 model flywheel bolts, ARP Triumph 2
hondo402000 TR6 TR6 ARP head bolts Triumph 4
S I just bought ARP main stud kit 206-5405 Austin Healey 4
L ARP fastners. Spridgets 4
M ARP head studs Triumph 5
Basil ARP studs too short Triumph 18
DNK ARP Studs Triumph 74
Glen_B Torque for ARP mains Spridgets 1
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
G ARP Assembly Lubricant....how to use the stuff Triumph 9
martx-5 ARP Head Studs Triumph 21
Morris ARP studs torque and blown headgasket Spridgets 17
Morris ARP Head studs torque... Spridgets 2
A ARP flywheel bolts--install Latest [no Loctite] Triumph 11
healeyboz ARP bolts Spridgets 6
healeyboz ARP bolts Spridgets 5
ChrisS ARP Rod Bolts Spridgets 7
ChrisS ARP Head Studs Racing 2
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Dog Bolt Torque—Crankshaft Triumph 11
JPSmit A fairly specific looking bolt Spridgets 10
F 59 bugeye spring bushing bolt Spridgets 8
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
R difficult bolt access Spridgets 8
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
B TR4/4A Starter dog bolt Triumph 15
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
