Using 12 point ARP style rod and main bolts
Fred_Maves
Member
I am reassembling a 1098 cc engine for my Sprite. During a previous rebuild I installed 12 point ARP stye rod and and main bolts. I discovered the remnants of blue Loctite thread sealer. Since, I have been given several opinions regarding the use of this product. The fact that typical tab locks will not match with the facets lead me to be somewhat concerned. Some say:
Torque the bolts dry w/o sealer
Use light oil
Use the higher heat rated red Loctite
Is there a consensus on this topic out there?
racingenglishcars
Fred_Maves said:
...Some say:
Use light oil
Apparently there isn't a consensus. I personally use blue Loctite. Maybe I should use red ??
Welcome to the forum.
Scott_Hower
"ARP style"?
I know ARP specifically recommends using their assembly lube, or alternately, some flavor of Loctite during assembly to achieve the proper torque preload.
I would not assemble these dry, but that's just my opinion.
MichiganTed
Torque specifications are developed for fasteners as received from their manufacture with some torque tension residual fluid on them. The fluid might be cutting fluid, rust preventative, etc. But either way, it isn't removed to develop torque specifications. Doesn't matter if it's a rod bolt, an intake support bracket bolt, or a tie-rod end. So in general, torque specifications are "wet". Remember that what maintains bolt tension is the amount the bolt stretches as the threads try to pull away from the head of the bolt during run down. That's why long bolts have a better torque retention (and lower torque spec) than short bolts: longer = more stretch.
If you use dry bolts with dry threads (which is almost impossible to achieve) a significant amount of your torque measurement will go into friction, up to say 40%. The result will be a under-torque condition.
Blue vs Red loctite really comes down to if you want to be able to service the joint in the future (generally a blue formulation) or if you never ever want to have the joint come apart again (generally a red formulation). Critical fasteners like rod and main bolts won't ever get hotter than your peak oil temperature. And with tab locks, you really don't need any loctite but if you must - I'd go with blue. The tab locks only need grab a small bit of the hex to be effective.
Loose the locking tabs, use the supplied with part ARP assembly lube, motor oil if you don't have that, you always want to lube these sort of high torque internal engine fastners to get a true torque, so never dry and never with loctite. Fred this advice come from a professional MG street and race engine builder with over 25 years of experience, and I don't build any of my engines, street or race with out ARP fastners, so a product I use very often.
F
Fred_Maves
Member
Hap,
Thanks, when I picked up my reworked cylinder head at my area machine shop the "head" shop guy concurs with your opinion. He even gave me enough ARP to use free of charge.
Being a Freshman member, I was pleasantly surprised by the quick, helpful responses to my first post. My next one concerns the correct piston alignment given no obvious front/back markings.
Thanks again,
Fred
The rod numbers are stamped to help to orient them. (check the manual I do not remember which side they point to).
The ARP rod bolt used in a 948/1098 engines isn't actually listed as such in the ARP catalog, or website but rather on thier universal rod bolts listed as 1.5" 3/8" univeral part number, they are perfect for the 948/1098 connecting rod as for lenght, shoulder length and such, many of us A series race engine builders have been using this part number for many years with these rods.
BlueMax
I’ll share a personal word of caution using ARP fasteners. Something you will discover that your main and rod housing will have dimensional change, in my case over a thousandth of an inch. So if you go the ARP rout do a mock build with the ARP torques then take your measurements of your housings. If any change, hone rods and mains for the correct tolerances’ that you’ll need to be applied in your engine build for the proper clearances!
Yep, thats correct, you don't change the fastner type and not resize (ARP or otherwise) thats engine building 101, meaning resize the big end of the rods, and line bore/hone the mains. Also you should never replace rod bolts, even stock type and not resize your rod's big ends. In fact I think no bottom end rebuild should be done without, at minimum, the rod's big end sizing being checked.
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
CJD General Tech Boeing using Lucas parts? Triumph 7
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
B TR6 Timing using a vacuum gauge Triumph 13
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
Nelson Using timing light Spridgets 17
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Using Midget Suspension parts on Nash Metropolitan MG 10
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
T Anyone using an LED light like this Triumph 39
