TR2/3/3A Clutch bleed using"gravity bleed" method?
karls59tr
Bronze
Who was it that mentioned that he had great success bleeding the clutch hydraulic system by just taking the cap off the resevoir ,opening the slave bleeder and letting gravity bleed the system while monitoring the level in the resevoir. Does this really work and how long does it take to accomplish?
tdskip
Not sure I'd want the cap off for that long. As with the Mitvac thread might be easier to just slowly pump the pedal until you get close then use a vacuum device or helper to finish it. It is a small line with little overall distance, shouldn't take long.
K
karls59tr
Bronze
Thanks for the info. I haven't had much luck with all the other methods so I thought I'd give this a try. :eagerness:
CJD
Me too. You can bleed the reservoir dry in about 5 minutes, so it doesn't take long at all. The only stipulation is that you have to have a primed MC. If there is still a big bubble in the MC, sometimes it takes a few pumps to get the brake fluid started.
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
Jim_Gruber Did my clutch just bleed itself? Spridgets 11
K TR4/4A Hey CJD...gravity bleed clutch MC and slave? Triumph 6
princetn1 MGB Clutch Bleed MG 3
M General MG Midget clutch bleed - engine out MG 3
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
R T-Series Still No Luck With Clutch Bleed MG 15
D clutch bleed ? Spridgets 2
steved033 Clutch stuck, a bleed doesn't help. Austin Healey 20
SCguy bleed clutch? Triumph 3
R T-Series MGB Clutch Bleed Solution MG 5
RedTR3 TR2/3/3A TR3 Clutch slave bleed screw size Triumph 4
Woodie how do you bleed a clutch? Spridgets 12
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
