5 speed conversion using the Datsun clutch assembly
Rut
I'm gathering info on the various 5 speed conversions and I prefer the Datsun clutch assembly. That said, how do you ballance the clutch, flywheel, and crank as an assembly? I have a local machine shop that can machine the flywheel for the Datsun clutch, but this ballance issue has me concerned.
Rut
Hot Wings
Rut
By dismantling the engine!
But unless you are dealing with a crank that uses external counter balance weights this shouldn't be needed unless you are after the ultimate in sub gram balance precision. If you are worried have the balance of the removed flywheel checked. If it is way off of balance as a discrete unit then you may have a problem. Swapping flywheels is a common activity and rarely causes a problem with balance in the real world.
If the original flywheel for some reason is way out of balance the technician doing the work may be able to duplicate the same imbalance in the new flywheel. Proper indexing would then be critical on reassembly.
Rut
Rut
I've not talked with the machine shop about the balance issue yet and everything will be apart when I take it to them, crankshaft, flywheel, clutch assembly. My 1275 was rebuilt, but some things need to be addressed. The compression ratio is 12:1, the rear scroll needs to be adjusted/line bored, cylinder walls need a little Scotch Brite, tolerances need to be checked, etc. The engine runs great, but I'm not too sure it's street able in its current configuration.
Rut
nomad
Rut, good luck on gas for a 12 to 1 engine now day's! If you have ethanol blender pump's you can probably make it work.
Kurt.
Rut
Rut
Kurt,
once I know how the PO got the compression up to 12:1 I'll know how to solve the issue. If he shaved the head I have a replacement from another 73 that's virgin, if it's the block I'll have to replace that as well. Looking for 10:1 max!
Thanks, Rut
Jim_Gruber
Rut, Just talk to Gerard and be done with your research. He'll take care of the flywheel as well. It fits into a Large Post office Flat Rate box and for 12.95 it ends up in San Diego at Gerard's Shop where he give it to a guy who has done many of these already and you don't have someone experimenting on your one and only flywheel. His clutch slave adapter bracket allows you to use a standard Spridget Slave and you won't need to do any special engineering. It's a bolt on and you are done.
Jim_Gruber
Bill, Gerard is in San Francisco.
BlueMax
Rut,
Not knowing what your CR can and will cause issues. Never go on hearsay or assumptions. But it’s quite easy to know all the answers by doing the math. Simple way is have you a deck height bridge https://www.benchmarkarizona.com/Deck_Bridge__Magnetic__standard_3_hole-8-126-193.html. Take this measurement and record it. Second you need to have the head sitting level at both axes placing a ¼ “Plexiglas with two ¼” holes in it. I like to use colored denatured alcohol so you can see clearly. Pick up a graduated cylinder at CVS that’s Milliliters or CC’s, either one will work if ML you can use a conversion chart. I like this CR calculator best, https://www.rbracing-rsr.com/compstaticcalc.html. Grease the outside of combustion chamber and set Plexiglas tight to head and fill one hole up to bottom of other hole. Plug all the rest of the information in and you will have your answer. You can use your deck gauge in helping to dial in your CR after you CC head by dropping the tip down to fluid which will tell you how much you need to mill head.
Clutch, flywheel pressure plate; these are personal issue to weather your looking for performance or standard leisure driving. The heavier the flywheel the longer it takes to spin up. Heavy flywheels are better for starts but not coming off corners and such. If you want a light flywheel 7.5 lbs Fidanza is a very nice set up and you will not have to balance it because it comes ready to install, pressure plates are already factory balanced. If the 1275 clutch doesn’t hold up to your style of driving you can move into the Tilton clutch. Remember a smaller mass diameter will provide a quicker gyroscopic rotation.
one milliliter = one cubic centimeter
BlueMax
That would make some great possibilities.
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
roscoe 5 speed conversion question Austin Healey 9
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
M TR6 5 speed conversion Triumph 33
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
rjc157 TR6 5-speed conversion Triumph 7
E TR6 Eaglegate 5-speed conversion help Triumph 1
mctriumph For Sale 5 speed conversion kits [formerly by eaglegate] Triumph Classifieds 3
rjc157 TR6 5 speed conversion Triumph 7
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
M The value in 5 speed conversion Spridgets 18
Rut 5 speed conversion Spridgets 4
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
Keith_M 5-speed conversion or not Spridgets 57
Mickey Richaud Midget 5-Speed Conversion Spridgets 6
bugedd 5 speed conversion trans oil Spridgets 7
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
JodyFKerr Spitfire Spitfire 5-speed conversion Triumph 9
Rut 5 speed conversion wish list Spridgets 28
B Healey 5-Speed Conversion Austin Healey 27
Gliderman8 5-Speed Conversion - Shifter Triumph 10
Gliderman8 5-Speed conversion Latest Triumph 13
HealeyPassion Question for 5 speed conversion guys Austin Healey 13
jhorton3 New Project...5 Speed Conversion! Spridgets 17
M AH 100 5 Speed conversion questions Austin Healey 21
prb51 Gear ratio/speed conversion Triumph 0
healeyboz 5 speed conversion Spridgets 15
CCURTISS T-Series TF Engine Lift Points for 5 speed conversion MG 3
CCURTISS T-Series MGTF 5 Speed Conversion MG 3
64rocksprite 5 speed conversion thoughts? Spridgets 7
gsalt57tr3 5 speed conversion for the 1500cc midget Spridgets 5
J Morgan 5 speed conversion Other British Cars 8
Sparkie New 5 speed conversion for 280i guys TVR 32
mgbmedic MGB MGB or TR6 -- 280Z 5 Speed Conversion MG 2
Bob McElwee Toyota 5 Speed Conversion Questions Austin Healey 10
budk1953 5 Speed Conversion Question MG 6
Hap Waldrop Rivergate 5 speed conversion questions Spridgets 42
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
LeeMcKee TR6 TR6 Five Speed Conversion? Triumph 5
kyreb1862 MG 5 Speed Conversion MG 20
S 5 speed 210 conversion and shifter question? Spridgets 7
PeterK 5-speed conversion pic Triumph 17
W 5 Speed conversion gear box MG 3
S Rivergate Five Speed Conversion Spridgets 6
77_MG_Midget 5 speed tranny conversion Spridgets 9
B Rudd Speed Conversion Austin Healey 3
MGA Steve Spitfire Spitfire 1500 5-speed tranny conversion Triumph 0
