AH 100 5 Speed conversion questions
musme
I am thinking about the smitty 5 speed conversion using the toyota gearbox.
I have a few questions.
1. Where does the gearbox lever finally rests ??
2. Does anyone has pictures of a AH 100 with the conversion ?
3. What is the final ratio of a AH 100 with overdrive in 4 th gear and wat is the final ratio with the 5 speed conversion ?
4. opinions in favor and against doing the conversion
5. other options different than the Smittys conversion
6.
Thanks
Jose Vargas
Bogota Colombia
South America
dougie
Hello Jose -
Smitty no longer exists. It's now "Healey 5-Speed", you should contact Pete
(704) 455-2585 or Healey5Speed@aol.com. He can answer all your questions. I have found their conversion to be the simplest and most cost effective here in the states considering you can purchase a good used Toyota 5-speed for about $300.00.
Dougie
M
musme
I was refering to Pete at Healey5speed.
But my concerns are more of kwnowing the experience of someone who has already installed the conversion.
Thanks,
dougie
Jose -
Many members of our local club the AHCO, as well as myself have installed this conversion. It's the only one I would recommend. The Toyota tranny is race proven and is as near 'bullet proof" as a tranny can be. Here's some further info. for you. https://www.austinhealeyclub.co.uk/index.html
Dougie
M
musme
Dougie
It seems you have installed the conversion on a 3000 ?
I am already convinced that the onley one I could install in the one from TN (Healey-5peed).
But I m not convinced about the final location of the gear lever... basically
I am looking for a Ah 100 owner who has installed the conversion. If you know of someone please let me know. Thanks.
The info from the AH club in the UK is great.
Thanks,
Jose
dougie
Jose,
I can't help with a 100-4 5-Speed install, but the Toyota W58 & W59 trans came with 4 different shift positions. Measured from the front face they're 18", 20", 21", 21.5". The 18" version fits into the BJ8 stock console within 1/2".
Dougie
steveg
Jose,
This (hopefully there's an image here) shows my BN6 setup with the forward-most Toyota shift lever position which is in front of the stock ashtray position. I believe this is identical to your BN2 setup as my car had the same sideshift transmission.
[img:left]https://www.pbase.com/image/115164110[/img]
GregW
Hi Steve,
Hmmm, worked for me. I followed your link, right clicked on the image and chose "copy image location". Then used "insert non-floating image" with a paste.
Johnny
dougie said:
Jose -
I recall a fellow club member putting a Toyota 5 speed in a BT7 and didn't have any problems. However, after wanting to remove the flywheel later on did have a problem with the tranny not wanting to come out of the thrust bushing. Has anyone else had this problem?
steveg
When I did mine, the nose of the Toyota input shaft was too tight in the ball pilot bearing so I used wet-dry paper to sand a very small amount off the shaft so it would be a slip fit in the ball bearing. A small smear of anti-sieze would probably be good, too.
Michael Oritt
Jose--
Here are four pictures taken of my 100 in which I have the Smitty's conversion which I think will answer questions 1 and 2. As I remember Smitty sold the kit with options to install the gear shift lever in three positions--I chose the furtherest forward. My wife has a BN7 that came to us with the conversion already in place and her stick comes out where the ashtray should have been--aside from the loss of the ashtray the stick feels too far back for my liking.
I have no info on question #3 but as to #4 I am heartily in favor of the conversion. The Toyota box is strong and a pleasure to shift. I also have no info on #6 though I do think there is some European source for a similar conversion.
Michael Oritt
M
musme
Thanks to all.... the pictures... the ideas ... the advices....
I have a pretty good picture of the situation:
1 and 2. The pictures show the position where the shifter knob rests. Not exactly as the original but centered....
3. The final gear ratio of a BN2 gearbox with overdrive is 0.78. The Final ratio of the W58 Toyota gearbox is 0.78 = the same
4. Everyone is in favor because of the comfort and forgetting about the overdrive mess, Lucas electrics and how complicated it is.
5. Smittys is the only option.
Thanks to everyone
busybrit
All good stuff but your wrong when it comes to Smitty being the only option.
I did my BN-1 conversion using a Celica box, Flywheel, Centerforce clutch, Celica starter and clutch slave cylinder, TR3 master cylinder - same as the AH 3000 and a prop shaft made by Cline of Greenville S.C.
Oh!,, Bell housing,,,I used the Celica Bellhousing together with a 1" thick, 14" Dia Alloy disc, - $28 off eBay - for a back plate.
There's not much of a space between the block and the body of the starter. I didn't like the gear lever, so I used the bottom off the Celica welded to the top from a TR3 and had it rechromed.
This link shows my car, engine sounds horrid due to the low quality camera I used.
https://www.youtube.com/results?search_query=austin+Healey+100&search_type=&aq=f
TonyR
Looks like a good conversion, nice car by the way.
Have you any dimensions for the hole centres on the 1"" plate?
I was thinking of doing a gearbox conversion for my BN1 and using a Triumph OD gearbox from a TR6 or the like.
Thanks,
Tony
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
J Owners of my 100-4 Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
H 100-6 Interior Installation Austin Healey 4
