T-Series MGTF 5 Speed Conversion
CCURTISS
I have been looking at the Moss 5 speed conversion for my wife's TF, has anyone done a Moss 5 speed or another 5 speed kit on a TF?
I have a few questions and I also want to make sure there are no other options before I do the Moss kit.
Thanks!
bill_young
Glenn, I've seen several posts on the Moss Forum https://www.mossmotors.com/Forum/ from guys that have installed the 5 speed kit in TDs and all were positive. It appears to be well engineered and set up as a bolt in with no damage to the car so it is completely reversable. Not cheap, but from what I've heard really makes the car more drivable. That's also the feedback from a couple of guys who have done the Moss kit in MGAs as well.
jessebogan
I had to straighten one out on a TD. It had been "sorta" installed by another shop. Since I had not put it in in the first place, I had a couple of conversations with the Moss tech staff.They were helpful,and pretty good about getting the needed parts. I think that the floorboards need to be trimmed, and the metal "Inner rails" by the trans tunnel also need to be cut back.There are braces that attach to the crossmember to hold the inner edges of the floor up. The people who butchered in this mans kit, left them out, and Moss could not supply them at that point. I fabbed up something that worked OK.All in all, it seems that it is an OK kit, and it helps the car cruise a lot better in modern traffic. What do you want to know, maybe I can help.
CCURTISS
CCURTISS
Jesse,
Thanks for the reply, I was trying to get an idea of how long it takes to install the kit. Moss claims the only cutting is to the trans cross mount and I wanted to see if it was really just a bolt in in real life. I hate making a modification where I can not easly bring the car back to origional. Heaing about having to cut floor borads concerns me a bit.
CCURTISS T-Series Moss 5 Speed in MGTF Complete!!! MG 2
PAUL161 T-Series MGTF Ignition Key MG 7
PAUL161 T-Series MGA pressure plate verses MGTF pressure plate? MG 6
PAUL161 T-Series Rare 1954/55 MGTF Accessory MG 23
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
G Pre-War how to start a 55 mgtf. MG 3
G T-Series 1955 mgtf 1500 lites MG 5
PAUL161 T-Series Original 1955 MGTF Photos MG 6
PAUL161 T-Series $68,995.00 MGTF MG 5
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
mgbmedic T-Series Return to Forum / MGTF Restoration MG 6
JPSmit Mgtf Spotted 1
C T-Series Stuck exhaust valve on 54 MGTF MG 10
C T-Series 1954 MGTF [not the new TF] gearbox MG 4
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
F T-Series Looking at a 1955 MGTF today- what's important? MG 8
Magyar T-Series MGTF Windshield MG 6
Magyar T-Series MGTF Dark Red Engine Paint MG 7
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
PAUL161 T-Series Victor MGTF [Sebarnes] MG 0
S T-Series Victor MGTF MG 17
CCURTISS T-Series MGTF Lower A-Arm Busing Replacement MG 1
CCURTISS T-Series MGTF 1500 Cooling Fluid Leak MG 6
CCURTISS T-Series MGTF Firewall [what goes in what hole] MG 2
CCURTISS T-Series MGTF Carburetor Size MG 1
CCURTISS T-Series MGTF Flywheel and Pressure Plate Torque??? MG 2
CCURTISS T-Series MGTF Shifter Rattle??? MG 4
C T-Series Nanjing MGTF MG 15
drjimwbrown T-Series Wonderful drive in MGTF down the Jersey Shore MG 5
swift6 T-Series Fun Hot Rod MGTF... MG 4
Bret T-Series Sighting MGTF in San Diego CA. MG 3
B T-Series MGTF "Upgrades" MG 11
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
