TR2/3/3A Using DOT 5 Brake Fluid On TR3A
Quelch
Member
Does anyone know if you can use synthetic brake fluid (DOT 5) safely on a Triumph TR3A brake system.
My TR3A has DOT 5 in it which was put in by the previous owner (I am told 5 years ago). The system appears to work Ok but I do have concerns about the long term durability of the seals.
Can anyone advise?
sail
Many views if you do a search. I am changing over to DOT 5 today if I get in gear. I'd say good sign previous owner researched what he was doing even if you don't agree.
6TTR3A
I used DOT 5 in my 3A twenty-one years ago; I flush and replace the fluid every 8-9 years...never a seal problem...It did render my brake switch inoperable so after the 3rd failure I rigged a mechanical switch. Details on the mechanical replacement have been dealt with on other posts. The nice thing about DOT 5; It won't eat your paint if a leak or spill occurs.
TR3driver
Great Pumpkin - R.I.P
I've been running DOT 5 in first my TR3A and now my TR3, for a total of something like 20 years. My experience is that the seals last much longer with the DOT 5 than with conventional brake fluid. There is also basically no corrosion of metal components (while conventional fluid becomes rather corrosive in service).
ISTR it was around 1990 when I rebuilt the front calipers on the 3A with new seals & DOT 5. They are still working great today. I thought the bleed screws might be seized as I hadn't touched them since installing the calipers, but when I moved them from the wrecked TR3A to the current TR3, they weren't stuck at all.
And hopefully, I'll never have to see this again (clutch slave from TR3, stored for 25 years with DOT 3 inside)
Q
Quelch
Member
THanks for the information Guys. I've just been reading on another forum that other people have had trouble with their brake switches using DOT 5. apparently there's something in the diaphram that the fluid deteriorates. One person say's that a Harley Davidson brake switch P/N 72023-51D (which is designed for synthetic fluid) can be used.
As mine has failed twice,I think I'll go that route!
Thanks again.
TR3driver
Let us know how the Harley switch works out. I also had brake switch trouble, but wasn't sure at first whether it was the DOT 5 or the high output brake light bulbs. So I solved both problems (along with some other changes) and I'm very pleased with the result
(PS The camera tends to exaggerate, they aren't really that bright. But they are quite a bit brighter than original.)
Geo Hahn
Many years w/ DOT 5 and the brake light switch has not failed... but I did put a relay on that circuit as I have more bulbs/amps than original.
Scot1966
I rebuilt/replaced the TR3A's entire brake system 2 years ago and decided to go with DOT 5. When I was rebuilding the system, all the componants looked like Randall's slave! That was why I went with DOT 5. It has worked flawlessly since.
mallard
I wish I could say I always had good results. Here are a couple pictures from my brake master cylinder rebuild a couple months ago. The cylinder was new from TRF when the DOT5 was put in 6 years ago. Fluid started to run down the front of the servo, that's how I noticed the problem. My clutch slave cylinder fails every three years. I't's now part of my tune-up I do every other year to rebuld the slave cylinder. I think the brakes are going to be watched much closer for now on. Look inside the reservoir to see if there is any black inside. If there is it's time for a rebuild. I always buy the best parts you can get at the time for the rebuild.
Look at the seal in the first picture and notice how much it has swelled, it's also very soft.
mallard
This last picture is of the small cup on the other end of the shaft. It is just mush. I don't know it it's because my west facing garage may get up to 130 degrees in the summer or not. The fluid used was the NAPA brand. I'm going to try another brand in the TR3 this time. I wish I could say silcone works great but unless you are going to keep up on it don't use it.
lazybird
A can of worms, to be sure. I've used DOT5 in my TR3 for 25 years. Never a problem. Wired a relay into the brake light switch circuit; never a problem there, either.
Ted Enderle
GBRandy
I wonder if the rubber compound used to make the seals matters and the process is not really regulated dependent on the fluid used
ie, most recipe compounds work with DOT3 but only certain recipe's work with DOT5. The user's results are really nothing more than a crap shoot with dramatically different results based on what box you got.
sd80mac7204
A lot of new cylinders i have seen, mainly for TRW branded parts, all say "USE OF SILICONE FLUID WILL VOID WARRANTY". I guess it causes enough of a concern that they do not want involved.
TR3driver
That may be exactly the case.
It is apparently not true any more, but it used to be that Girling seals were not compatible with American DOT 3 brake fluid either. I didn't believe it at first, but I did a test where I rebuilt all the cylinders in my (previous) TR3A with new seals at the same time, and filled the system from a fresh can of Wagner brand fluid. Drove the car around the block a few times to be sure everything worked as it should, then parked it for a few months. 2 months later, both rear brake slaves and the clutch slave had leaked enough to drain the reservoirs!
Then I switched to Castrol brake fluid, and had no further trouble for a year or two. Of course, that is the same car where one of the hard lines rotted through, and left me with no brakes while going downhill into an underground parking garage (with no outlet). The car was no great loss, but I sure do miss that engine...
If I had to change all the seals to convert to DOT 5, I would still feel that it was worth it.
One other anecdote: When my first (and only) new car (a Chevy) got to about 80,000 miles, one of the front calipers started to leak. I replaced the one caliper with a rebuilt, and converted to DOT 5 by just bleeding through (no flushing). After that, I never touched the hydraulics again. They were still working fine when the car got junked with over 250,000 on the clock.
mallard
I wish I could get the right recipe. I bet going downhill with no way out and no brakes was a real eye opener. The cylinder was not a TRW brand, but all the internals may come from the same place except fot the company that makes them out of the right material.
glemon
I have used silicone in a couple of cars now with no issues, the first was my Healey, I drained and flushed the old system, then blew the lines out with air, then in went the DOT 5. I didn't disassemble and clean or rebuild anything.
I drove it for 9 years after that no hydraulic issues.
The current TR250 is all new or rebuilt hydraulics, no issues on the dot 5.
I don't have exact figures, but recall having periodic leak/replace/rebuild issues when I ran Castrol LMA, not every time a went to run the car, but certainly not as good as the record with DOT 5. I too have concluded it is better on my seals.
I know others have had issues, so maybe it is the luck of the draw with the seals.
I have also heard people say it is harder to get the bubbles out when bleeding, again I haven't had issues.
mallard
It's got to be more than the luck of the draw with as many people here that are having great results. Maybe it was the NAPA fluid that I was using. This time it's going to be the red and white bottle Cartel brand that you get from Moss. I hope it works well.
TR3driver
I stumbled across a white paper today, written by Michael Grant at Moss Motors about brake fluid. Here's an interesting quote from that paper:
<span style="font-style: italic"><span style="font-weight: bold">What About the Stories of Silicone Brake Fluid Causing Seals to swell?</span>
These stories abound on the internet, but I have not actually spoken to the person it happened to, so I cannot comment on the actual incident that started the story. We do know that it is very, very unlikely that a brake fluid meeting FMVS 116 would do that. The testing is designed to make that sort of thing impossible. I can tell you that the literature is full of reference to the grotesquely swollen and gooey seals that you get if the brake system is contaminated with petroleum based oils or solvents. It does not take much of this kind of contamination to ruin all of the seals in a system. The contamination can usually be traced to the use of improper cleaners, rags contaminated with motor oil or grease, or handling the seal with hands that have petroleum based contaminants on them. We have tried to duplicate these reported problems by soaking brake cups in DOT 5 fluid, but we have never found a problem. However, these stories have a life of their own and it is doubtful that they will ever go away.</span>
Full text at https://www.mossmotors.com/SiteGraphics/Pages/Brake_Fluid/brake_fluid_long.html
TR3driver
I overlooked this before; it reflects a potentially dangerous misconception. All brake fluid is "synthetic", it is not petroleum based at all. Typically in the past, the cans did not say "synthetic", today many of them do. It doesn't mean anything at all.
<span style="text-decoration: underline"><span style="font-weight: bold">Only</span></span> "<span style="font-weight: bold">DOT 5</span>" brake fluid is actually silicone-based.
Even "<span style="font-weight: bold">DOT 5.1</span>" is <span style="font-weight: bold">not </span>silicone based and does not share it's characteristics (except for a very high boiling point).
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
CJD General Tech Boeing using Lucas parts? Triumph 7
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
B TR6 Timing using a vacuum gauge Triumph 13
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
F Using 12 point ARP style rod and main bolts Spridgets 9
Nelson Using timing light Spridgets 17
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Using Midget Suspension parts on Nash Metropolitan MG 10
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
T Anyone using an LED light like this Triumph 39
