Using timing light
Nelson
I recently had my distributor redone by Jeff and I'm ready to install it. He said to set the timing to 10 to 14 degrees BTDC at idle. I just bought a new timing light to use for the setting up but I am not sure how to procede. With my 948 engine's timing marks being at the bottom of the engine and the dizzy on top how can I move the dizzy and see the timing marks at the same time? The only way that I can think of is to move the dizzy a little and then lay down to see the marks and repeat the process until the timing is correct. Is there an easier way to do this?
dklawson
There is hope though. Call Jeff back and buy one of his timing pointer kits. The kit allows you to install a pointer on the timing cover and a timing tape on the front pulley. Jeff has pictures of the kit on his web site.
Nelson
Nelson
I saw that Jeff has the kit but he says it is for the 1275 engine and that made me think that my 948 must somehow be different for that application.
dklawson
I suspect what may be different between the 1275 and the 948 would be the front pulley. Jeff may not have a timing tape suitable for the 948. However, that doesn't have to stop you. You could still install the pointer and put simple paint marks on the front pulley.
You didn't mention if the new timing light was a simple light or an advance timing light. If you bought an advance light you only need to put a single paint mark for TDC on the front pulley.
Nelson
Nelson
I do have the advance type of light so I'll have to see about putting a new timing mark up top. Thanks
dklawson
Great. With an advance type light all you need is a pointer mounted up high aimed at the rim of the front pulley and a single paint mark to accurately locate TDC. Your advance timing light will make up for the lack of other marks on the pulley. (i.e. If you want to find 8 BTDC, set the light for 8 BTDC and run the engine. Wherever the TDC mark is stationary will be 8 BTDC based on how you adjusted the timing light.)
Jim_Gruber
OK so I got one of Jeff's Kits with the timing strips and am not confident I got the pointer and strip on the pulley correctly aligned. Guessing I could look to see if Timing was set to 8 degrees BTDC how it compares to the pointer and the strip. Sure that would do it. I've got an extra one of those strips that he sent me if I installed it wrong. OK another task to accomplish to put on the Job Board, recheck timing.
jlaird
LOL
Nelson
Nelson
Jeff at advanceddistributors.com sells the kit for $20. It is designed for the 1275 engine and I have a 948 so I didn't order it. He also sells a tool to locate exact TDC but it is out of stock right now. I'm thinking about taking an old spark plug and making my own based on the picture of the tool on his site.
G
I use a screwdriver.
dklawson
I have used a dial indicator with a bent piece of coat hanger zip tied to the tip as a probe extension. Reach through #1 spark plug hole with the wire resting on top of the piston. That allows you to find TDC as accurately as when the head is off.
JPSmit
bug_sixty said:
who said a metal mirror on the floor won't solve this little annoyance
Just mind that everything will be reversed
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
regularman Using a timing light Spridgets 8
B TR6 Timing using a vacuum gauge Triumph 13
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
CJD General Tech Boeing using Lucas parts? Triumph 7
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
F Using 12 point ARP style rod and main bolts Spridgets 9
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Using Midget Suspension parts on Nash Metropolitan MG 10
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
