TR2/3/3A Using a timing light for setting TR3 Timing
sammy
Member
Before you set me straight, I do know that the timing on a TR3 should be set without the engine running. My question is, couldn't someone set the timing using the static method, then start up the engine and use a timing light to determine where the timing mark winds up? This position could be used to set the timing in the future with the engine running.
Has anyone done this? If so, when should the initial setting be? Using an adjustable timing light would give the exact setting.
Am I wrong on this?
Sam
bgbassplyr
Either way works. Static to get a starting point, then light to refine. ISTR that if idle is too high, light will not read the static setting correctly due to advance weights beginning to do their thing. You can rev the engine and use the light to determine total advance. Disconnect the vac advance to read only the mechanical advance.....reconnect the vac to get the added advance.
Watch out for the fan hitting your light or fingers.
Geo Hahn
Seems possible to me - set per the manual then once it is running well get a benchmark using a timing light. That reference could then be used later for setting directly with the light -- provided you have exactly the same RPM next time.
Hardly worth the trouble though since the static timing is so easy and can be done irrespective of engine temp, air temp, oil weight, carb adjustment etc - IOW all the other things that could affect running RPM and timing.
The timing light is very useful for seeing total advance though.
martx-5
:iagree:
As Geo says, hardly worth the effort. Also, if you are using the original distributor, once the static timing is set per the factory procedure, adjustments can be made with the knurled nut on the distributor. No matter how much you play with it to obtain "perfect" performance from you particular engine, you can always go back to square one with the turn of the knob.
TR4nut
What they said - I do like having a timing light with the advance feature to check things though. Gives a nice confirmation of everything, also you can roughly check on advance characteristics vs RPM.
Nelson Using timing light Spridgets 17
regularman Using a timing light Spridgets 8
B TR6 Timing using a vacuum gauge Triumph 13
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
CJD General Tech Boeing using Lucas parts? Triumph 7
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
F Using 12 point ARP style rod and main bolts Spridgets 9
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Using Midget Suspension parts on Nash Metropolitan MG 10
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
