Paging Martx-5...What valve gap are you using?
karls59tr
Bronze
I see from my previous post on carb needles that we have similar cams in our TR3 engines. I am curious to know what intake and exhaust valve gap you're using? .014 for both? Karl
K Paging Randall re: Judson Supercharger Vanes Triumph 5
HealeyRick Paging Dr. Entropy Lotus 0
K TR2/3/3A Paging TR3driver re blocked bypass and Shaller pdf Triumph 1
K TR4/4A Paging TR4nut re Timken speedi sleeve? Triumph 4
Tabcon Paging Kai Radicke of Wishbone Classics!!! Triumph 11
7 paging Andrew Mace Triumph 4
K Paging Mike P. re BritishIron wrecking yards? Jaguar 3
K Paging Andrew Mace: Re Spifire engines Triumph 1
T Wedge Paging Monica - Is happy TR7 motoring underway? Triumph 5
T Paging Don - exhaust pic needed please Triumph 9
K TR2/3/3A Paging TR3Driver re: trunnion outer washers... Triumph 4
K TR4/4A Paging TR4 nut....re front suspension Triumph 2
K Paging Doug F ....regarding Petronix Warning Triumph 3
davelgee Paging Miss Agatha Spridgets 16
J Paging Basil! Check it out..The cars a blast! Other Cars 6
Basil Paging Steve - RE: Zaino Restoration & Tools 3
Basil Paging Jagboy! Jaguar 0
71TR6 TR2/3/3A Slight tweak to Martx-5's dogleg covering method Triumph 9
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ā€˜74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
