Paging Randall re: Judson Supercharger Vanes
karls59tr
Bronze
In one of your previous posts on the original Judson supercharger you mentioned that there was an issue with the cooling vanes where pieces would break off and fall into the engine once the vanes wore down. You said the vanes were made from "phenolic linen" I believe. Why was that material used and what kind of material do you suppose they use for the vanes on the newer Judsons?
TR3driver
Great Pumpkin - R.I.P
How they arrived at that material, I don't know. But from having spent some time trying to find a better material, I suspect it was simply the best one available at the time. The vanes have to be dimensionally stable (can't grow or shrink with changes in temperature, pressure or humidity), and have a long life with very minimal lubrication. They also have to handle impact well without chipping or breaking, and not tear up the housing they run in.
Oddly enough, I happened to have a relatively recent air impact gun apart the other day. It not only has an air motor that works on basically the same principle (in reverse of course, instead of turning the crank to move air, it uses air pressure to turn the crank); but the vanes in it appeared to be exactly the same material!
As far as I know, no one has made new Judson-type superchargers in a long time (like 40 years or more). Rootes-type blowers are better in almost every way and are now readily available in sizes that suit a 2 liter motor. (For example, the TR2-4 blower kit from Moss uses a Rootes-type blower made by Eaton I believe.) However, I found a web site that purports to be by the Judson company:
https://www.judsoncompany.com
It talks about having some new parts made to the original specs, but hasn't been updated since 2008 (which I suspect means it never happened).
One of the users on the Team.Net Judson mail list posted back in 2003 that he was going to try Torlon vane material. Unfortunately I seem to have missed his report on how well it worked, and the archives don't work. Just for kicks, though, I looked up Torlon sheet. $652 for a square foot! (which wouldn't be enough to redo a TR3 Judson)
https://www.professionalplastics.com/TORLON4203
K
karls59tr
Bronze
Thanks for the info. I know someone with a Judson on his 3 and apparently a piece of "metal" got into the valve seat area of a cylinder and destroyed the valves and the piston. Remembering your first post I thought it was likely a piece of vane. How hard would it be to access the vanes in the supercharger to see what kind of shape they are in?
angelfj1
I grew up near Judson's plant. Later in high school, me and my friends would hang out there and watch hot rodders attach Judsons to their cars right in the dirt parking lot. I later met some of the guys who worked there. The original designs were made just after WWII and at that time there were probably few non metallic materials to fit the application.
TR3driver
If the cylinder head is already off, then inspecting the vanes should be pretty easy, I think. But I still haven't gotten around to disassembling mine, so I'm just guessing. Here's the service instructions for the VW version; I'm guessing the TR should be similar:
https://docs.google.com/open?id=0B2H2NJt34OffNDkxMDY3NDItYTM4OC00MGQzLWIwYzctNmY3MGViOWYxYzAy
And here is a photo from a friend, where you can see the bolts to remove and one of the holes for the forcing screws:
HealeyRick Paging Dr. Entropy Lotus 0
K TR2/3/3A Paging TR3driver re blocked bypass and Shaller pdf Triumph 1
K TR4/4A Paging TR4nut re Timken speedi sleeve? Triumph 4
Tabcon Paging Kai Radicke of Wishbone Classics!!! Triumph 11
7 paging Andrew Mace Triumph 4
K Paging Martx-5...What valve gap are you using? Triumph 0
K Paging Mike P. re BritishIron wrecking yards? Jaguar 3
K Paging Andrew Mace: Re Spifire engines Triumph 1
T Wedge Paging Monica - Is happy TR7 motoring underway? Triumph 5
T Paging Don - exhaust pic needed please Triumph 9
K TR2/3/3A Paging TR3Driver re: trunnion outer washers... Triumph 4
K TR4/4A Paging TR4 nut....re front suspension Triumph 2
K Paging Doug F ....regarding Petronix Warning Triumph 3
davelgee Paging Miss Agatha Spridgets 16
J Paging Basil! Check it out..The cars a blast! Other Cars 6
Basil Paging Steve - RE: Zaino Restoration & Tools 3
Basil Paging Jagboy! Jaguar 0
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
PeterK General TR Sad news about Randall Triumph 48
glemon General TR Randall Young "Tr3driver" Update, Wish Him Well Triumph 65
T TR2/3/3A Randall Young? Triumph 10
Graham H TR2/3/3A Randall's Trick Triumph 10
K TR2/3/3A Randall...Re: tire pressures Triumph 10
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
K TR2/3/3A Randall....Ammeter Shunt when there are spade connectors? Triumph 2
B Off Topic Question for Randall Triumph 1
Lukens TR2/3/3A Randall, let's try this Triumph 4
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
K TR2/3/3A Randall....another trunnion spindle issue? Triumph 5
K TR2/3/3A Randall.....4:35 Diff in a TR3? Triumph 4
B Randall is correct. This has been a nightmare! Triumph 19
O TR2/3/3A TR3 Misfire +[ Randall you're correct again] Triumph 10
glemon Turn Signal Question Up-date Success Thanks Randall Triumph 23
T Randall - how was the Yosmite drive? Triumph 4
T TR2/3/3A Randall - how is your TR3 coming along? Triumph 3
Jim_Stevens TR2/3/3A Judson Supercharger on eBay Triumph 0
M Judson Supercharger On A 1275 Spridgets 6
H Judson Supercharger Spridgets 11
BillyB62 TR2/3/3A Judson supercharger Triumph 5
HealeyRick Judson Supercharged BE at Auction Spridgets 10
PAUL161 T-Series Judson Supercharger Question MG 2
K TR2/3/3A Judson Supercharger Plumbing Setup for TR3??? Triumph 4
C TR2/3/3A TR2/3 Judson F/S Triumph 9
K Anyone ever run a Judson Supercharger on a TR3? Racing 1
K TR2/3/3A Judson Supercharger in a TR3? Triumph 15
chrpark Opinions/Experiences on Judson Supercharging 948's Spridgets 5
6 Who Knows About Judson Super Chargers Spridgets 2
boxofparts MGA NOS-MGA Judson Supercharger kit-what is it worth? MG 12
jollyroger Judson Supercharger Spridgets 3
