TR2/3/3A An alternate valve adjusting sequence?
karls59tr
Bronze
Someone suggested this in a previous discussion as a valve adjustment sequence instead of using "the rule of 9".
Set timing mark at TDC and check for closed valves. It comes in one of two sets: #'s 1 2 3 5.....and #'s 4 6 7 8
Now adjust the closed valve set.
Rotate the crank 360 degrees and adjust the new closed set.
Is this a workable method?:unsure:
Geo Hahn
I like to be very sure I am at the point of fully closed so I will continue to use the old method. Either way, seems like it is twice around to do them all.
Sarastro
With the "rule of nine" method, you can be sure that the lifter of the valve you are adjusting is on the heel of the cam. That's because the cam lobes are precisely 180 degrees apart. Because of that, you can be pretty sloppy with the position of the crank and still get accurate results. There's a lot of room for error.
The way you are suggesting, if I follow it, is like this: At the top of the compression stroke, the intake and exhaust cam lobes are pointing downward, not straight down but plus and minus maybe 40 degrees from straight down. That should still be on the heel of the cam, but the cam doesn't have to move far before it moves away from the minimum. So, you have less room for error. But if you are careful, it should work.
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
T Front Flip Hood Alternate Latching Spridgets 12
SD Bugeye Alternate alternator Spridgets 20
SherpaPilot TR6 Alternate Door Jam Light Switch Triumph 4
SD Bugeye Alternate alternator Spridgets 5
aeronca65t Alternate Detroit Auto Show Other Cars 5
Jim_Gruber VIN number alternate locations - Somewhere by front suspension????? Spridgets 20
H alternate to plating? Austin Healey 7
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
tomshobby Alternate routes for the 50th in Wisconsin Spridgets 2
T Weather and Transportation - alternate thinking? Spridgets 43
texas_bugeye Alternate Alternator Spridgets 3
Dadandson Alternate Alternator? Spridgets 12
boeingpilot TR4/4A Alternate differential for TR4A Triumph 4
bill_powell Alternate Seats [again] Spridgets 17
kodanja An Alternate Alternator? Triumph 88
Nunyas Alternate "basic" transportation... Other Cars 29
Ed_K Alternate way to cure fiberglass resin ? Austin Healey 14
F Alternate Seats? Spridgets 17
norcalnewb Alternate Sprite Interior Colors Spridgets 7
S Wedge Alternate/After Market Wheels for TR7 Triumph 6
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
