alternate to plating?
Hawkscoach
Gentlemen, this is getting exciting to be putting parts back on! Several smaller electrical bits I would like to install before putting the engine/trans back in. What do you guys use to "plate" the metal on these parts. Are there alternatives to sending out. for example: Flasher relay cover...........thanks, Doug
Bead blast and chrome paint. Does not look chrome at all like advertise but it does look similar to a silver cad plate. Eastwood also sells paints to mimic plated parts, but I find the chrome plate does the same for less.
Although I have never done it I have heard some people will spray a clear coat finish (as used with modern automotive topcoat paints) on unfinished metal surfaces.
Hawkscoach,
There are DIY cad and zinc plating kits available to brighten small metal parts. Is that what you are looking to do?
thanks guys! yes, CLEAh, I am trying to get the look close to the original. If I bead blast they will be a rough almost primer look (although the rust will be gone). I also have an "environmentally friendly" water based fluid from Eastwood (pricey) that works ok on lightly rusted bits. I have seen many of restored AH pictures and wasn't sure what to use.................thanks, Doug
I had all my parts CAD plated and baked. It is brighter and shinery than the orginal Zinc plating. CAD adds a few thousands to the thickness to the parts and those that are worn will have/could their original thickness restored. Cost was about $40 (plus/minus), for a gallon paint can full. I've had a couple of guys on the BCF ask me where to get CAD done and I gave them a Contact in the Ft worth, TX area that I use. They responded back that they were happy with the work and service.
I've used the Eastwood zinc plating kit, got good results but there are a couple things you need to know. First, the parts must be absolutely clean and derusted. And small flakes in a pit or trapped in threads or such can leave a streak in the plating. Ans second, the battery source to power it is way too small for any piece of any size. I use an old toy train controller to run the plating. Depending in the size of the piece I adjust the "throttle" up or down since it controls the DC current. When complete, rinse off with water, dry and buff lightly with very fine steel wool.
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
T Front Flip Hood Alternate Latching Spridgets 12
SD Bugeye Alternate alternator Spridgets 20
SherpaPilot TR6 Alternate Door Jam Light Switch Triumph 4
SD Bugeye Alternate alternator Spridgets 5
aeronca65t Alternate Detroit Auto Show Other Cars 5
Jim_Gruber VIN number alternate locations - Somewhere by front suspension????? Spridgets 20
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
tomshobby Alternate routes for the 50th in Wisconsin Spridgets 2
T Weather and Transportation - alternate thinking? Spridgets 43
texas_bugeye Alternate Alternator Spridgets 3
Dadandson Alternate Alternator? Spridgets 12
boeingpilot TR4/4A Alternate differential for TR4A Triumph 4
bill_powell Alternate Seats [again] Spridgets 17
kodanja An Alternate Alternator? Triumph 88
Nunyas Alternate "basic" transportation... Other Cars 29
Ed_K Alternate way to cure fiberglass resin ? Austin Healey 14
F Alternate Seats? Spridgets 17
norcalnewb Alternate Sprite Interior Colors Spridgets 7
S Wedge Alternate/After Market Wheels for TR7 Triumph 6
B TR6 Chrome plating Triumph 13
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
F Pewter Chrome Plating Restoration & Tools 10
R Chrome plating MG 21
Lin re-zinc plating for fasteners Austin Healey 8
RickAnderson Cost of Chrome Plating Restoration & Tools 5
B windshield pillar plating Austin Healey 2
Basil COrrect plating for Brake Booster? Jaguar 9
kurts100 Concours Experts--Zinc Plating or Cadmium Plating? Spridgets 10
D plating at home Restoration & Tools 3
dklawson Caswell Plug-N-Plate Plating Kits? Spridgets 3
dklawson Caswell Plug-N-Plate Plating Kits? Triumph 3
Tinkerman Chrome Plating Costs Triumph 13
T Chrome plating recommendations Triumph 8
Tinkerman TR2/3/3A Chrome Plating the 3A valve cover $$$$$$$$$$$ Triumph 16
Basil Plating - sources? Restoration & Tools 3
toysrrus "CHROME PLATING"-Found or Lost Art???? Triumph 18
timbn2 plating small items....and Caswell products???? Austin Healey 3
Brosky More on Chrome Plating Triumph 13
toysrrus "Chrome Plating" Lost Art or are they Still Around Triumph 22
Brosky Chrome plating in New England Triumph 9
B Chrome Plating Austin Healey 5
GregW Caswell nickel plating kit Restoration & Tools 3
John Loftus Caswell Copy Cad/Zinc plating kit Restoration & Tools 83
Randy Forbes Chrome Plating Up-date... Austin Healey 4
G chrome plating Austin Healey 10
Basil Plating some parts - Heart attack! Jaguar 17
