TR2/3/3A Rule 9 Valve Adjustment
R
Redoakboo
I am starting to adjust the valves in my TR-2 following Rule 9.
After closing # 8 and adjusting #1, closing #7 and adjusting #2, closing #6 and adjusting # 3, closing # 5 and adjusting #4. How do you go back and adjust 8,7,6,& 5?
Dick
Platinum
Dick,
First, let's deal with nomenclature. And nevermind that "rule" thing. A valve is "open" when the rocker is holding the spring compressed fully. It's "closed" when the rocker-to-stem can be clearanced.
You should notice when #8 valve is fully OPEN (not "closed" as you state), the rocker arm fully depresses the spring there. Adjusting clearance on its opposite (#1) is possible. The same goes for all the rest: When #7 valve spring is fully depressed, you can set clearance on #2 rocker. Conversely, when #2 valve is completely compressed (valve opened) you can adjust #7 rocker clearance. That goes for all the rest as well. Depressed spring on #4 (open valve) and adjust #5, depressed spring on #5 (again valve fully opened) and adjust #4 clearance...
Put another way, if the valve 3 from the front of the head is fully open (spring completely compressed), then the third valve from the REAR of the head is fully CLOSED and the rocker clearance can be set. And the opposite is true. Third from the rear compressed, third from the front is adjustable.
CJD
Interesting rule. I don't think I could ever remember it, though. I just set the crank at TDC at the crank marker and the distributor rotor pointed at the #1 spark plug. At that setting you can adjust both cyl 1 valves. Rotate 90 deg clockwise and set the #3 cyl valves. Another 90 to TDC again and set #4 valves, and 90 more to #2 valves. It's easy to tell which cylinder to set, as the valves will both be loose, while the other cyl will have at least 1 tight valve.
Platinum
Either method gets "close enough". Biggest "rule" is: "Too loose is better than too tight"!!
poolboy
I think, I hope you meant something like this:
#8 fully open, adjust #1
#7 " " ....adjust #2
and so on
Then:
#1 fully open adjust #8
and so on.
bobhustead
My rule is (1) pick any cylinder, (2) turn the engine so the exhaust valve opens and closes (goes down then up) (3) keep going til the intake opens and closes (4) turn the crank another 45 degrees or so (5) adjust both valves. Pick another cylinder and do it again.
Bob
poolboy
On a TR6 (6 cylinder engine) Rule of 13 we actually get 2 valves simultaneously OPEN and have 2 CLOSED to adjust at a time.
For instance....When 1 and 3 are simultaneously OPEN we adjust the CLOSED 12 and 10 valves..and so on
IF... you have 2 simultaneously open valves on your 4 cylinder engine see if there are 2 closed that will add up to 9 with the open valves.
K TR6 Rule of thumb for frt suspension shims Triumph 6
Mark Bailey Old tire rule? Restoration & Tools 5
F TR2/3/3A RULE#1 Never throw anything away Triumph 3
HealeyRick Everybody Wants to Rule the World Austin Healey 8
Basil So you Healey guys want to rule the world? Austin Healey 6
drooartz Drew breaks his rule and becomes an MG owner Spridgets 15
jlaird Bugeye rule of thumb Spridgets 4
drooartz Air tools rule Spridgets 39
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
