MGB MBG valve clearance
dpsmgb
Member
Good evening,
I have owned my 1975 MGB for four years but only had it on the road last fall. It runs well but has noticeable valve clatter. I checked clearances, one is .015 but most are .012-.013..should I set all to .015?
It was checked cold.
Mickey Richaud
If engine is stock, .015" cold setting is the norm. However, some folks tighten them up a bit to reduce clatter without causing any harm. I wouldn't go less than .012", especially on the exhaust valves. And follow the "Rule of 9" when adjusting - when #1 valve is closed, adjust #8; when #2 is closed, adjust #7; #3 closed, adjust #6, etc.
Good write-up here: > MGB Tappets <
:cheers:
Mickey
W What year did MBG do away with Chrome numbers? MG 22
M Help! 71 MBG with Starter Run on Problem MG 2
Lynn Kirkpatrick MGB-GT MBG GT door seals MG 17
T MGA MGA/MBG cam bearings - FS MG 0
Shinsen774 Painting 1964 MBG Heater MG 2
K Replacing MBG choke cable MG 2
G Got an MBG! MG 7
aeronca65t IRS-MBG [not tax-related] MG 0
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ā€˜74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
