TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks?
Geo Hahn
None. I drove as I pleased until a valve receded to a point where I could no longer adjust it - then I got hardened seats and a general rebuild of the head.
Pump gas seems adequate octane wise - but of course that depends on what rating you have available, compression ratio of the engine, amount of advance, altitude, etc. I just get the usual at the Shell station and tune to make it work.
TR3TR6
I did the same as Geo, had the hardened seats put in and a total rebuild. I just use the 91 octane gas and it runs fine.
Lou Metelko
Also did nothing more than a set of valve springs with hardened seats in 2003. The TR2 has had a steady diet of 87 octane since. Proud to say it has been 38,000 miles and counting!
Lou Metelko
Auburn, Indiana
M
Momikey
Really? How come everything I read recommends it. My engine only has 6000 miles on it so I thought it would be a good idea to help it run for a long time. Interesting.
Geo Hahn
Really? How come everything I read recommends it...
Wellsir, it is certainly recommended by the companies that make & sell it.
I do carry a bottle of octane booster in the boot in case I get into remote areas where only low octane fuel is available (have encountered this a couple of time on the reservation).
Even at that, I suspect the increase obtained from its use is slight as they use some misleading terms when stating the number of 'points' it increases octane.
Vila
I don't drive my antique cars hard and have never had any problems.
The one thing I do different then most is use ethanol free 91 octane gas. This is mainly because my 1933 Chevrolet gets vapor lock if I use gas with ethanol and the fuel lines run around the front of the engine similar to my TR4 and tend to heat up the fuel line. The ethanol in gas vaporizes at a lower temperature then the gas and from what I have read on the AACA forum can cause vapor lock.
TR3driver
Great Pumpkin - R.I.P
Much better IMO to buy oil with the ZDDP already in it. Motor oil additive packages are carefully crafted, just dumping in another additive may make things worse instead if better. Plus, too much ZDDP is definitely worse than not enough.
I use Valvoline VR1, but there are others
On the lead substitute front, I did run Redline for awhile, as my "barn find" motor was definitely having a problem with recession. But I've owned lots of others that never had a problem, and the original head (no hardened seats) that I dropped on as a temporary replacement seems to be doing fine (after 10k miles or so). So my advice is to save your money unless a problem becomes apparent.
glemon
What Randall said, the concerns about valve recession when they took out of gas does not seem to have turned out to be as bad as some projected. I have run a number of cars for a number of years without hardened valve seats and haven't seen any problems. If it were a daily driver I might be more concerned, but I put couple thousand miles a year or so on my Triumph, will probably have some other major malady befall my car (or me) before I have terminal valve recession.
I run Valvoline VR1 as well, I noticed the straight 50w was on clearance at Advance Auto, hope they are not phasing the line out. Brad Penn is a popular choice too, though a little harder to find, there are others as well as Randall mentioned.
Geo Hahn
FWIW - My valves held up fine w/o hardened seats until the day I drove from Riverside CA to Tucson AZ doing 80-85 all day long. They didn't seem to like that much - no real harm done though, just prompted me to get the seats.
Kleykamp
I bought some lead substitute at a local auto parts store and put it in a previous TR3 I had. Ended up with a carb full of lead substitute. Rebuilt them again and didn't use the crap after that. I'll drive till it needs something then fix it. Lots of possibilities likely to be there before valve seats. I use Shell 91 gas. I will say it seems to run better with 91 vs 87 octane, but that could just be the way I have it tuned in.
CJD
The seats that take the most pounding are those that are operated at high speed for long periods. Of all of us on the forum, I think Tex is the only one that really applies to! If you just beat around town, I think the carbon build up tends to protect the seats from excessive erosion.
S Gas additive, Lead Substitute - BJ8 Austin Healey 9
rjc157 TR6 Lead Substitute Triumph 5
L Valve seats and lead [substitute]. Spridgets 18
prb51 Valve seat recession/ lead substitute Triumph 2
R Lead substitute Restoration & Tools 13
Y Lead Substitute Austin Healey 1
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
Rut Lead for bodywork Spridgets 5
D Lead additive Jaguar 12
Sopwith_Camel lead lights Jaguar 6
S Austin Healey LEAD replacement in gasoline Austin Healey 4
aeronca65t Lead East this weekend [in NJ] Other Cars 0
M ignition coil high tension lead connection Spridgets 10
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
J Lead my gas..? Austin Healey 3
B Lucas lead 'helmet-type' battery cables Austin Healey 5
drambuie looking for a good lead fuel additive Austin Healey 5
tri_carb_healey leaky lead carb Austin Healey 6
JamesWilson Holes- Lead Loading Restoration & Tools 0
K Zinc and Lead Again? Triumph 15
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
bcbennett Radio antenna lead Triumph 3
Tr4dude How does a paint chip lead to this? Triumph 13
7 neat tool to make your own lead hammer. Restoration & Tools 10
vping MGB Lead Seams - '63 MGB MG 4
JamesWilson Can Aluminum be Lead Loaded? Restoration & Tools 3
K Lead/Tin 50/50 Triumph 7
74WannaB Lead work on 74 B MG 3
J TR6 anyone have a lead on a body tub for tr6 Triumph 2
RickB lead additive? Spridgets 9
J TR4/4A Anyone have a lead on a wiper switch for a TR4A? Triumph 8
S Lead or octane boost? Austin Healey 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
AweMan Soldering Lead and Silver Restoration & Tools 10
G Red Lead Primer Triumph 5
jlaird Todays question, no lead head Spridgets 7
mgbmedic about lead substitutes... MG 16
jaybird Lead additive Spridgets 13
R Lead-Free Cylinder Heads Austin Healey 10
Mark_Gibson Wedge A Good Lead on TR-7's and 8's for Sale Triumph 2
DerekJ #6 Plug lead arcing Austin Healey 4
D no lead cylinder head conversiom Triumph 7
Mark_Gibson Another British Parts and Service Lead Triumph 0
G Lead Head Knock-off Hammer Austin Healey 10
2 Lead Additive Triumph 6
aeronca65t "Lead" Fuel Additives? Restoration & Tools 21
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
B TR4/4A Hylomar substitute Triumph 4
