Lead-Free Cylinder Heads
rustynuts
I had the valve seats on the heads of my 327 redone last year and was wondering if the head on my BN1 needs to be done?
zblu
Re: leadfree cylinder heads
Its only the valve guides need replacing!, a few $'s, but the labor cost to do it!
vette
Hello Rusty, many years ago (about 18 to 20) I was concerned with the same question for my Corvette engine. After reading many articles and listening to many opinions it was the general concenses that lead free gasoline would need about 50,000 miles at least to damage valves and valve seats in an engine which was designed for leaded gasoline. this was confirmed thru then current test in some respected motor magazines. The general feeling was that many collector cars would never see an additional 50k on the odometer. So I like many elected to not change my valves and seats. As it would yeld no benefit to our motoring. Now 20 years later my Corvette engine has never been torn down and still lights the tires up at will. I have put about 35,000 miles on it in the last 20years. /ubbthreads/images/graemlins/cheers.gif
Louie
If it works, don't fix it.
Many of these normally simple jobs can take the cars off the road for a LONG time !
Editor_Reid
Platinum
I have heard from several reliable sources that such work is unnecessary unless you're planning to use it for competition or for lots and lots of miles, such as a vintage race car that you also use as your daily grocery-getter. Of course opinions may differ, and several mechanics, working at $XX per hour, may strongly recommend that you employ them to perform this job...
Keoke
[ QUOTE ]
[/ QUOTE ]
HI ZBLU,the valve guides do not have to be changed as part of a non leaded head conversion if they are it is the owners choice. The pricipal components effected if any are the valves themselves and their seats.---Fwiw---Keoke /ubbthreads/images/graemlins/cheers.gif
R
rustynuts
I basically heard the same thing when I did the 327. It has 461 heads and I have kept the car as it would have been built ( which it was) in the 70's. The seats and valves in the 283 that was in the car when I bought it where screwed so the decission to rebuild was not an option. Glad I did .
What year of vette do you have?
vette
Rusty, I have a 1970 Corvette. It's a 350/350hp, completely original with the hydralic cam. Just one step up from the base engine, but it is one of the last of the non-emissioned engines. I've had this e-mail address and internet handle for probably 12 years or better. Couldn't bring myself to change it just because I bought a Healey a few years ago. The Healey was a car that I've wanted for 35 years or more. The way I see it, I've got the best of both worlds now, American power, and British touring.
zblu
Was told the guides needed changing to a diff composition due to the lack of lead in the fuel needed to act as a lube Keoke, havent done the changeout myself, just put some avgas in now and again!
GregW
I’ve heard that the lead lubricated the valve to seat surface. The fear was without it, the seats would wear away and the valve would recede into the head over time.
Keoke
Yep Greg, you heard right---Keoke /ubbthreads/images/graemlins/grin.gif
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Gas additive, Lead Substitute - BJ8 Austin Healey 9
Rut Lead for bodywork Spridgets 5
D Lead additive Jaguar 12
Sopwith_Camel lead lights Jaguar 6
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
rjc157 TR6 Lead Substitute Triumph 5
S Austin Healey LEAD replacement in gasoline Austin Healey 4
aeronca65t Lead East this weekend [in NJ] Other Cars 0
M ignition coil high tension lead connection Spridgets 10
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
J Lead my gas..? Austin Healey 3
B Lucas lead 'helmet-type' battery cables Austin Healey 5
drambuie looking for a good lead fuel additive Austin Healey 5
tri_carb_healey leaky lead carb Austin Healey 6
JamesWilson Holes- Lead Loading Restoration & Tools 0
K Zinc and Lead Again? Triumph 15
L Valve seats and lead [substitute]. Spridgets 18
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
bcbennett Radio antenna lead Triumph 3
Tr4dude How does a paint chip lead to this? Triumph 13
7 neat tool to make your own lead hammer. Restoration & Tools 10
vping MGB Lead Seams - '63 MGB MG 4
JamesWilson Can Aluminum be Lead Loaded? Restoration & Tools 3
K Lead/Tin 50/50 Triumph 7
prb51 Valve seat recession/ lead substitute Triumph 2
74WannaB Lead work on 74 B MG 3
J TR6 anyone have a lead on a body tub for tr6 Triumph 2
RickB lead additive? Spridgets 9
J TR4/4A Anyone have a lead on a wiper switch for a TR4A? Triumph 8
S Lead or octane boost? Austin Healey 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
AweMan Soldering Lead and Silver Restoration & Tools 10
G Red Lead Primer Triumph 5
R Lead substitute Restoration & Tools 13
jlaird Todays question, no lead head Spridgets 7
mgbmedic about lead substitutes... MG 16
jaybird Lead additive Spridgets 13
Mark_Gibson Wedge A Good Lead on TR-7's and 8's for Sale Triumph 2
DerekJ #6 Plug lead arcing Austin Healey 4
D no lead cylinder head conversiom Triumph 7
Mark_Gibson Another British Parts and Service Lead Triumph 0
Y Lead Substitute Austin Healey 1
G Lead Head Knock-off Hammer Austin Healey 10
2 Lead Additive Triumph 6
aeronca65t "Lead" Fuel Additives? Restoration & Tools 21
J For Sale FREE! 2 fiberglass aftermarket hardtops, supposedly big Healey but NOT BJ8 (close though) Austin Healey Classifieds 0
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
