TR6 Lead Substitute
rjc157
Just picked up a 75 tr6 with no emissions and no blower pump has anyone heard of adding a lead substitute to the gas I had 5 tr's from a 69 to a 76 and never did that am I missing something right now it's running like crap
poolboy
I've heard of it, but don't believe it's necessary.
Could be as "simple" as the carbs or it could need a tune up...or it could be a mechanical problem.
"Running like crap" frankly isn't much to go on if you get to the point of asking for help with the diagnosis.
rjc157
rjc157
Just picked it up tonight didn't have a chance to go through it could adding the lead substitutes do any damage to the valves
TR3driver
Great Pumpkin - R.I.P
Not likely to do any damage, but it is not going.to help either. If lack of lead is the reason it runs poorly, then the exhaust valves are already ruined and nothing short of a valve job is going to fix them.
Like Ken said, start with a major tuneup, including compression test & valve adjustment. If you find one or more exhaust valves that are tighter than spec, you might possibly benefit from lead substitute. But normally a TR6 should not need it.
TR3driver
That's a big clue right there. Good chance something was done wrong when stripping off "all that emissions junk".
S Gas additive, Lead Substitute - BJ8 Austin Healey 9
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
L Valve seats and lead [substitute]. Spridgets 18
prb51 Valve seat recession/ lead substitute Triumph 2
R Lead substitute Restoration & Tools 13
Y Lead Substitute Austin Healey 1
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
Rut Lead for bodywork Spridgets 5
D Lead additive Jaguar 12
Sopwith_Camel lead lights Jaguar 6
S Austin Healey LEAD replacement in gasoline Austin Healey 4
aeronca65t Lead East this weekend [in NJ] Other Cars 0
M ignition coil high tension lead connection Spridgets 10
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
J Lead my gas..? Austin Healey 3
B Lucas lead 'helmet-type' battery cables Austin Healey 5
drambuie looking for a good lead fuel additive Austin Healey 5
tri_carb_healey leaky lead carb Austin Healey 6
JamesWilson Holes- Lead Loading Restoration & Tools 0
K Zinc and Lead Again? Triumph 15
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
bcbennett Radio antenna lead Triumph 3
Tr4dude How does a paint chip lead to this? Triumph 13
7 neat tool to make your own lead hammer. Restoration & Tools 10
vping MGB Lead Seams - '63 MGB MG 4
JamesWilson Can Aluminum be Lead Loaded? Restoration & Tools 3
K Lead/Tin 50/50 Triumph 7
74WannaB Lead work on 74 B MG 3
J TR6 anyone have a lead on a body tub for tr6 Triumph 2
RickB lead additive? Spridgets 9
J TR4/4A Anyone have a lead on a wiper switch for a TR4A? Triumph 8
S Lead or octane boost? Austin Healey 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
AweMan Soldering Lead and Silver Restoration & Tools 10
G Red Lead Primer Triumph 5
jlaird Todays question, no lead head Spridgets 7
mgbmedic about lead substitutes... MG 16
jaybird Lead additive Spridgets 13
R Lead-Free Cylinder Heads Austin Healey 10
Mark_Gibson Wedge A Good Lead on TR-7's and 8's for Sale Triumph 2
DerekJ #6 Plug lead arcing Austin Healey 4
D no lead cylinder head conversiom Triumph 7
Mark_Gibson Another British Parts and Service Lead Triumph 0
G Lead Head Knock-off Hammer Austin Healey 10
2 Lead Additive Triumph 6
aeronca65t "Lead" Fuel Additives? Restoration & Tools 21
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
B TR4/4A Hylomar substitute Triumph 4
