Anyone using a MaxJax on a BN2 ?
musme
I am installing my MaxJax and I am wondering if anyone is using a MaxJax with a BN2. I have concerns about clearances specially the muffler. Should I use extenders ? All input is welcomed
bighealeysource
Bronze
I'm like Randy, I could just see my concrete garage slab cracking along the line of the anchors about the time I'm sitting under the Healey. Always thought maybe I should be buried in it but not under it !
Mike
Ed_K
Don't the full height lifts of the same design also just fasten to the concrete floor ? It would seem to me that the lower height lift would put less stress on the mounting points than the full size units ?
My neighbor installed one of those lifts and it works like a dream. He has a 31 ford hot rod.
They sell different sized inserts to go between the arms and the car. You would have to be careful to put something between the lifting inserts and the car frame, just like when you use a floor jack.
Ed
Unless I'm mistaken, the maxjac is portable; does it even use anchors? That's what I mean about being scared (if it didn't...).
The full height one (in my garage) is secured with five (5) 3/4" diameter anchors for each column. Initial torque was about 125Lbs-Ft, and they recommend they be retightened, which I do about once a year. The first time I retightened them, the nuts "moved" a smidge, but I haven't been able to budge them since.
I'm still undecided if I'll take this lift to Florida, or leave it for the next owner of this house. If the house buyer wants it, it will be completely detached from the sale of the house, and I will accept no liability for its use. I;ve got my eye on a couple of better ones (ALI Certified).
Legal Bill
Randy, I thought the same as you, but when I looked at the site, I learned they are anchored. It is portable because you can detach the unit from the anchor and roll it away. I'm not sure what hardware you disconnect. If it is the anchors themselves, I would be concerned. I think once you have the anchors in place and tightened, you want to leave them alone.
healeynut
I have a max jax. You have anchors in the floor, which the towers bolt to.
You are supposed to have a minimum 4" slab of high pressure concrete, or failing that, a 12" concrete anchor. It is all specified in the instructions, it is all very safe but your garage may require some retrofitting if not poured properly. Most modern homes would have the proper concrete in the garage.
The system is very safe and frankly much safer than a jack / Jack stands which are not anchored to the floor.
The whole system is built to a standard worthy of use in a professional shop.
If for whatever reason the system would fail, you would get so much advanced notice with noise, cracking concrete, wobbling car, that you would have plenty of time to get out. And because you aren't lying on your back doing the work, your ability to get out quickly would be easy.
I mean, I know of three second hand stories of LBC owners getting crushed under their cars while lying on their backs with the car up on jack stands?
No thanks, I'll take the Max Jax.
Alan
Ed_K
The anchors are flush with the top of the concrete. All you do is unbolt the tower to floor mounting bolts after removing the arms. Once the bolts have been removed, the towers tilt over a bit onto the built in wheels so you can roll it out of the way to store them. My neighbor bought some quick disconnect fittings for the hydraulics so disconnecting the power unit from the towers is a snap.
I want one but have to wait until I save enough for a new/extra section in my garage door so it will hang close to the ceiling and then another 1800 for the lift.
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Anyone using an LED light like this Triumph 39
R Anyone using a Good GP2 cam? Triumph 7
L Anyone using SUs take note [with pictures] Spridgets 5
bighealeysource Anyone using an Allison or Crane on your Healey Austin Healey 7
livinginthepast Anyone using speed bleeders? Spridgets 7
RickB Anyone using Valvoline VR1 racing oil? MG 36
G Anyone using an adjustable clutch pushrod? Triumph 30
MadRiver Anyone using an Optima battery? Triumph 8
Brosky Adjustable clutch rods, anyone using? Triumph 16
T TR6 Anyone using TRF Roadspings on their TR6 Triumph 11
Brosky Hard plastic transmission covers - anyone using? Triumph 20
Basil Anyone remember Dave Russell? Austin Healey 10
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
