MGB Clevis pins, anyone?
Platinum
Found these in a tool box I'm doing a refurb on. Taken from customers' MGB's and saved as examples to stick on the "Wall of Shame" display.
Excess pedal free-play travel? Maybe there's a miniature crankshaft masquerading as a clevis pin involved:
pdplot
OK, Doc. Update on clutch problem. Friend Randy checked out clutch pedal and found reason for banging noise - worn clevis pin and egged out hole. He plans to get a new pin and sleeve the hole. The master cylinder was also leaking. We bled the clutch and restored the pedal. I had forgotten how stiff the pedal was when all the air was out. We will replace the M/C and S/C next weekend.
Platinum
:thumbsup:
SD Bugeye Clutch and brake clevis and pins Spridgets 3
S TR4/4A Handbrake cable rubber boot at clevis pin end Triumph 1
T TR2/3/3A TR3b Master cylinder push rod clevis Triumph 2
T TR2/3/3A TR3 clutch slave and clevis Triumph 4
TimK Clutch Clevis Pin Austin Healey 0
M clevis pin and slave pushrod misalignment MG 1
davester Brake pushrod and clevis pin repair? MG 7
M Lotus Europa Spiral Pins Lotus 9
Healey Nut King Pins Austin Healey 13
R TR6 Front suspension fulcrum pins Triumph 6
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
D 62 tri-carb upper fulcrum pins Austin Healey 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
6 1275 Head to block dowel pins Spridgets 10
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
D TR2/3/3A Mills Pins?? Triumph 11
Rut Bonnet alignment pins Spridgets 5
Healey Nut King Pins Austin Healey 4
H TR4/4A Worn Fulcrum pins Triumph 5
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
R bugeye king pins Spridgets 11
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
T TR6 TR4a vs TR6 fulcrum pins [was TR4a shims] Triumph 31
M Rear Suspension Pins Austin Healey 1
D King pins ?? Austin Healey 4
Jim_Gruber Bushings for Fulcrum Pins Spridgets 11
Jim_Gruber Removing Fulcrum Pins Spridgets 26
Jim_Gruber Replacing Fulcrum Pins and Bushings Spridgets 0
G 72 midget hood pins? Spridgets 3
PatGalvin TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn? Triumph 6
N lower link pins Austin Healey 0
M Healey King Pins Reamed in Wa. State? Austin Healey 5
T T-Series MG TC King Pins MG 4
M Rear Shackle Plate Pins Spridgets 12
W late BN1 brake spring anchor pins Austin Healey 14
Dougal Are these Healey 100 King Pins? Austin Healey 8
bash Refurbished King Pins MG 5
swift6 Adjustable Upper Fulcrum pins! Triumph 9
S Re-installing King Pins on BJ8 Austin Healey 5
hondo402000 TR6 Beefing up the Rear end Pins TR6 Triumph 9
heliguy TR5/TR250 TR250 clutch fork "pins" Triumph 2
6 Inserting cotter pins into castle nuts Spridgets 4
H 100 Gudgeon Pins Austin Healey 3
G Is this acceptable wear....fork pins Triumph 9
M TR6 TR6 Diff. Mount Pins Triumph 2
jlaird Hair pins Spridgets 1
miranda where to get new pins for the trunklid hinges? Austin Healey 13
vping Removing Fulcrum Pins Spridgets 10
D Fulcrum pins Spridgets 2
