MGB King Pins appear fine am I missing something?
Boggsy64
Before tearing apart the front end in my 1977 MGB, I read many threads online and it seemed certain that my old king pins would be completely worn out, thus the reason I bought the full rebuild kit. The axle / king pin assemblies I took out appear to be absolutely fine, there is no play in them, they turn freely, and no visible wear in any area. I do not want to buy the reamer required to size the new king pin bushes so I have not taken them apart. I plan on putting the old assemblies back in (they are a little dirty, but I don't expect anyone to see them). I will be replacing the seals, spacers, and other external bits that came with the kit, just not disassembling the main axle / king pin assembly. Am I missing something, some hidden catastrophe? Before I put it all back together I want to be sure.
Platinum
If (after thoroughly cleaning all the old grease out) you have a good fit, no worries. Usually the lower assembly where the a-arm is bolted thru the pin is the worst part for wear. Water gets to it and the bolt gets rusted to the sleeve and so begins to "eat" an oval hole in the a-arms. As long as the things are greased with regularity (and the rubber cups are intact) they should last indefinitely. You may have lucked out with a car that saw good maintenance practices over its lifetime.
JPSmit
I replaced the king pins but not the bushes - every report I saw says the bushes rarely wear and, I think I killed at least one kingpin removing it. If I had to redo the car, there are a few thing I would not have touched as I think the were still good - King Pins, wheels bearings are on top of my list. (and the replacements - especially bearings, aren't always as good)
Boggsy64
Boggsy64
Thanks. Both of you confirm what I thought. A couple of weeks ago I had tried to remove the kingpins and quickly realized disassembly was not going to be easy. I couldn't get the upper suspension link trunnion to budge so I stopped and rethought things.... if not broken don't break it trying to fix it!!
Healey Nut King Pins Austin Healey 13
Healey Nut King Pins Austin Healey 4
R bugeye king pins Spridgets 11
D King pins ?? Austin Healey 4
M Healey King Pins Reamed in Wa. State? Austin Healey 5
T T-Series MG TC King Pins MG 4
Dougal Are these Healey 100 King Pins? Austin Healey 8
bash Refurbished King Pins MG 5
S Re-installing King Pins on BJ8 Austin Healey 5
J HD8 shaft bushing & king pins. Austin Healey 6
Morris King pins Spridgets 22
EinsteinsDad T-Series MGTD Front suspension and Swivel / King pins MG 4
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
histerical Moss king pin reamer Spridgets 13
MY66AH King Pin Replacement Spridgets 14
S King Pin Bushings Austin Healey 1
PC rolling like The King... Jaguar 6
R King Pin kit Austin Healey 4
BN6_2197 Rmoving the King Pin [continued] Austin Healey 18
BN6_2197 Removing king pin from stub axle of BN6 Austin Healey 11
weewillie in king city today Spotted 3
Hap Waldrop King Tri metal Bearing MG 10
D Rubber Bumper King MG 6
G [Price] King Midget ? Spridgets 12
T King pin reamer Austin Healey 5
S King pin bushing reamer Austin Healey 4
J BN1 King Pin Nut Threads Austin Healey 1
aeronca65t King Midget, etc Other Cars 4
toysrrus "FOR SALE": KING DICK JACK, WRENCH & STORAGE BAG: Spridgets 11
B Front suspension king-pin reamer Spridgets 5
JPSmit King Pin question Spridgets 5
Morris King pin shims Spridgets 4
Morris King Pin Shims Spridgets 4
B King tri-metal bearings Triumph 4
B KING PIN UPPER BOLT MG 5
R6MGS F-150 King Ranch Other Cars 18
timbn2 whitworth / king dick tools... where to get.? Austin Healey 4
A New Vandervell replacement bearings by King Triumph 1
X King pin/Swivel axle MG 7
Gray_Cat Separating Fulcrum Pin from King Pin Spridgets 9
B King Pin Question Austin Healey 6
M Lotus Europa Spiral Pins Lotus 9
R TR6 Front suspension fulcrum pins Triumph 6
DrEntropy MGB Clevis pins, anyone? MG 3
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
D 62 tri-carb upper fulcrum pins Austin Healey 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
6 1275 Head to block dowel pins Spridgets 10
SD Bugeye Clutch and brake clevis and pins Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
