HD8 shaft bushing & king pins.
John_Progess
Is it normal to have to replace the king pins. I noticed that Moss's front suspension repair kit includes the king pins along with the bushing etc. Mine do look bad in the bushing areas in fact I had to use heat and a press to get them apart. Do the 2" SU's have a throttle shaft bushing already in the housing or do you have to drill out the housing and install a bushing like on the 1 1/2" carbs. Thanks for your help.
John
Keoke
HI John, I suspected that your king pins were frozen.I would renew the entire assembly. Regarding the HD8 carbs,in side the body surrounding the throttle shafts are a set of replaceable busings.Currently these are made out of Teflon 0.015" thick.and are included in the better rebuild kits.Never the less, if the shafts are worn they may need replacing too. I usually get the master kits and do it all.---Fwiw---Keoke
J
John_Progess
Thanks Keoke, that is what I figured and that is what I will do on both accounts. I think that is money well spent when it comes time to put this car back on the road. Have a good day!
John
john,i see your moving along rather well on your newly found love
[austin healeys]there is alot of stuff on 'king pin'in our archives,i know youll have many more questions on this subject as you proceed,it must be wonderful to be retired and have all that time to spend in the shop working on your project,at the rate your going youll have her totally rebuild next week!regards anthony7777 1963 bj7 M.K.II. /ubbthreads/images/graemlins/hammer.gif
J
John_Progess
Anthony,
I finally have the car completely dissassembled. I had to use heat and PB Blaster on at least half the parts on the car. It was a battle right to the last part but I won! Have a good day!
John
J
John_Progess
Anthony,
I have only just looked inside the AH tranny but it looks very similar to my MGTF in its layout. I have gone thru all my transmissions (2 MGA's, 1 MGTF). I have not done a OD tranny yet! It is interesting that AH never went to an all syncro transmission as MG did around 1963-64. Have a merry Christmass and a happy new year!
John
M New Member with an HD8 Carb Question Austin Healey 1
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
G HD8 Idle Adjust Screw Austin Healey 10
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
J Wanted HD8 SU carb set Austin Healey Classifieds 6
wangdango Colortune for HD8 Carbs? Austin Healey 55
B mysterious leaking of SU HD8 Jaguar 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
D S.U. HD8 Carburetor Drawing Austin Healey 6
S Float valves for HD8 - Grose Type Austin Healey 20
steveg HD8 high idle aggravation Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
D Rebuilding the SU HD8 carbs Austin Healey 24
pkmh HD8 SU Carburetor removal Austin Healey 48
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
D K&N filters for HD8 carbs Austin Healey 26
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
BOBBYR HD8 Carbs Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
A BJ8 SU HD8 carbs for sale Austin Healey 0
R Setting up HD8 carburetors Austin Healey 6
Lin HD8 carbs Austin Healey 2
