Wanted Orphan HD8 carburetor for parts
BoyRacer
Does anyone have a lone HD8 2" SU carburetor they would be willing to part with? I need various parts to complete a set that I am working on.
rossco
Mine are 1 1/2". Sorry. Learned something today. They are relatively unmolested. No floats or float bowl bolts. Manifold and crossover pipe is there. Interested? I could post a picture.
M I adopt another orphan Triumph 6
M MGB-GT Orphan B Roadster and C GT in NOVA MG 25
Sherlock Rescuing "orphan" cars Other British Cars 14
M New Member with an HD8 Carb Question Austin Healey 1
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
G HD8 Idle Adjust Screw Austin Healey 10
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
J Wanted HD8 SU carb set Austin Healey Classifieds 6
wangdango Colortune for HD8 Carbs? Austin Healey 55
B mysterious leaking of SU HD8 Jaguar 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
D S.U. HD8 Carburetor Drawing Austin Healey 6
S Float valves for HD8 - Grose Type Austin Healey 20
steveg HD8 high idle aggravation Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
D Rebuilding the SU HD8 carbs Austin Healey 24
pkmh HD8 SU Carburetor removal Austin Healey 48
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
D K&N filters for HD8 carbs Austin Healey 26
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
BOBBYR HD8 Carbs Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
A BJ8 SU HD8 carbs for sale Austin Healey 0
