HD8 drop test time in seconds
AUSMHLY
HD8 vacuum drop test
Hello all,
When performing a vacuum drop test with the HD8 carburetor piston and suction chamber, how many seconds should it take?
The two ventilation holes should be plugged (ear plugs) or taped (masking tape) over first, for an accurate reading.
Testing a pair of carburetors in a BJ8, if they don’t have the same drop time, what difference in time is acceptable?
Would there be a difference in performance if the drop test result was quicker or slower?
Example: better/worse gas milage or quicker/slower
acceleration?
Here’s a link to a video about how to perform a drop test.
Thank you.
Dandare
I have seen 5-7 seconds stated for 1.5"-1.75" throttle but can't see a figure for 2".
The factory stance was that a fast piston drop, if markedly so, gave a richening effect over standard tuning and vice-versa..."sometimes even taking the general mixture strength outside the range normally given by the standard needle"
Danny
Rob Glasgow
I'm guessing the speed of drop in this test is only to determine the consistency between both carbs. Once the masking tape is removed and springs reinstalled in the domes, those piston come down pretty fast, only restricted by the dash pot oil. So if the test drop for both is close to the same then anything in the 5 to 8 secs. Would be OK.
M New Member with an HD8 Carb Question Austin Healey 1
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
G HD8 Idle Adjust Screw Austin Healey 10
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
J Wanted HD8 SU carb set Austin Healey Classifieds 6
wangdango Colortune for HD8 Carbs? Austin Healey 55
B mysterious leaking of SU HD8 Jaguar 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
D S.U. HD8 Carburetor Drawing Austin Healey 6
S Float valves for HD8 - Grose Type Austin Healey 20
steveg HD8 high idle aggravation Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
D Rebuilding the SU HD8 carbs Austin Healey 24
pkmh HD8 SU Carburetor removal Austin Healey 48
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
D K&N filters for HD8 carbs Austin Healey 26
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
BOBBYR HD8 Carbs Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
A BJ8 SU HD8 carbs for sale Austin Healey 0
J HD8 shaft bushing & king pins. Austin Healey 6
R Setting up HD8 carburetors Austin Healey 6
Lin HD8 carbs Austin Healey 2
