Air cleaner for HD8 on BJ8
MarkA
Hi All,
Does anyone know of a K&N filter setup to fit the HD8's on a stock BJ8? I know that the Jags E type have HD8's also, but I don't think the filter size they use will clear everything in the engine compartment.
I have considered special ordering some blanks from K&N and cutting the bases myself. But, if there is something already out there, I would rather use them. If I do make my own, what filter area size would be good for a stock engine.
Thanks,
Mark
GregW
Hi Mark,
First I’ll mention that there is a vendor that advertises on this forum that I believe makes filters for a BJ8. Look on the left side of the page under “Supporting Vendors”. I think his name is Dave and seems like a nice fellow.
I have bought a fair amount of filters directly from K&N. I see they have HS6 carbs listed HERE . You can give them a call. They have many more filter setups than are listed on the website.
M
MarkA
Thanks Greg.
I checked with SuFilters and they do not make anything for the BJ8 because of the extreme offsets they would need.
I'll keep looking...
M
MarkA
Thanks Greg and DT.
I had seen those before. How do you like them? I have had a few foam filters for our quads and they seem to clog up must faster than our K&N or paper filters. It could mean they just caught more of the dust and dirt, or they did not have as much surface area.
I just want something that is easier to maintain than the stock filters. I hate waiting for the excess oil to drip out. It seems like it also takes a week for the stock cleaners to clear out the excess oil that did not drip out.
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
I T-Series air cleaner/ noise suppressor MG 1
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
G help with a part Id. cooper air cleaner? Other British Cars 1
Got_All_4 TR6 69 TR6 air cleaner color Triumph 16
F Coopers air cleaner decals- which way do they go? Austin Healey 2
P TR2/3/3A TR3 Air Cleaner Triumph 18
RAC68 Oil Spraying Air Cleaner MG 6
H filters inside of BJ air cleaner? Austin Healey 24
R Looking for Air Cleaner Austin Healey 0
CCURTISS TR2/3/3A 1957 TR3 Air Cleaner Options Triumph 4
G Air cleaner housing to carburetor gasket torn Triumph 3
M XK 140 cannister air cleaner Jaguar 1
H Air cleaner question MG 22
H SU air cleaner question MG 4
davidk TR6 TR-6 Air Cleaner Assembly Questions Triumph 10
C tr 3 backfiring into air cleaner Triumph 3
S TR2/3/3A Tr3 air cleaner color Triumph 4
johnrip Wedge TR7 air pump, and air cleaner Triumph 4
GlennLBC 1979 Air Cleaner MG 1
V Air cleaner hoses Triumph 10
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
