    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR6 69 TR6 air cleaner color
Got_All_4
Looking for the proper finish for the air cleaner box for a 1969 TR6. I'm quite sure they are black but gloss or satin black? This is not going to be a concourse restoration car but period correct.
I would do as little shine as possible with out going flat.
Also have it p'coated
I bought a new '69 TR6 and I don't remember the air cleaner being black. I remember a hammered silver color and the two short snorkels out of the front.
mine is / was rust and black. Just sandblasted and primed it. I know I've seen the gray hammered look before but not up on a 69 TR6. did not see any gary underneth it ether. mine could have been switch out.
Hmmm...if that be the case, which I never doubt Ken, if your is originally black.
Must be an early 69
There's a picture in the Piggott book of a 250 with the black box. That's how I came up with that, Don.
Maybe for some 69's it was a leftover or just a swap.
The left over is what I figured as you know, Triumph was good for that.
Swap is always a possible too.
I would think it would be the Silver that is used for a lot of the car.
But this is a WAG
What is the 69's body #
But fot the most part they were the hammered gray look?
When I mentioned "hammered silver" in my initial post, the "hammered" part is what i recall, but may not have been so. But, it was definitely a silver color similar to the wheels...after you took off those awful Rostyle hub caps they stuffed on the '69.
I'm going to the TRF Summer Party next week and got an e-mail from Charles tonight that some is going to be there with a new 1969 TR6. He had new in quotation marks so what does that mean.
Must be an early 69
CC29843​
First TR6 I had was a 69, unfortunately I don't have the commission number - but it was a silver air cleaner, I wouldn't call it hammered I think I used the same silver as I had used on my Spitfire wheel rims - argent silver?
You can buy that hammered gray look in a spray can. I'll find out next week. Got to be some one at TRf that knows.
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
G TR6 TR6 air filter element replacements for stock housing Triumph 3
D TR6 76 TR6 Stromberg Air Valve Triumph 2
hondo402000 TR6 New Tires and Air pressures TR6 Triumph 9
E TR6 TR6 Cold Air Induction - Mixture Triumph 2
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
hondo402000 TR6 Air suspension for Tr6 Triumph 1
floyd TR6 75 tr6 air injection system Triumph 8
T TR6 Where can I get a front air dam for a TR6? Triumph 10
JoeC TR6 TR6 Dashboard Fresh Air Vent[s] Triumph 1
tr6web TR6 TR6 Manifold gasket help Triumph 1
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
R TR6 TR6 Triumph 6
