TR6 75 tr6 air injection system
floyd
Looking for info on my missing Air injection manifold. I picked up a 75 tr6 from a friend that decided that he really didn't have time for this car after he bought it. It has not ran for about 4-5 years. I have noticed that the air jection manifold is missing. Is this injection system something that i should get backinto working order, or can i just plugged it off. It looks like the manifold is the only missing item. Thanks for any help.
RomanH
Look into the emission laws in your state. If they are as bad in Ohio as in Illinois you may have to put the whole system back together just to pass the smog test. If you don't have to have the smog testing done then I would say you are fine in leaving it off.
You may want to contact a local club and see what they have to say about the subject.
floyd
floyd
Thanks for your reply. I have this posted at 3 different forums and your the only reply I've gotten on this subject. I would not mind putting it back, but the price of a new manifold is about $300-350. Unless I can find a used one. Would you what this actually does for the car besides emission control. Or any long time effect it would have running without it?
Paul Johnson
Roman, the function of the AI system was to inject fresh air during deceleration, in hopes of thus burning off any CO and HC (carbon monoxide is partially burned hydrocarbon [gasoline]). This is now done electronically by shortening the fuel injector pulse width to 0.2 miliseconds. In pre-emission days, no once cared.
About the only negative effect on the car would be if you are still running a catalytic converter, which would become plugged in time.
bobh
Paul,
I don't think any TR6 came with a catalytic converter. My '75 is bone stock and does not have one. I don't think Triumph started using them until the TR7.
RomanH
Paul,
I think you wanted to reply to Floyd as I know what the AI was for.
Here in Illinois if you want to drive your car with no restrictions you have to get standard plates and not antique plates. So if you own a 68 or newer car you need to pass the emissions test. Also if you fail one time and come back for a re-test they can inspect under your bonnet and ding you for not having the pollution gear hooked up. That is why I suggested that Floyd look into the Ohio laws regaurding this.
Bobh is correct when he stated that the 6 doesn't have a catalytic converter, they all used leaded gas which would detroy a cat in short order.
Paul Johnson
[ QUOTE ]
Paul,
[/ QUOTE ]
Oops. Sorry, but today is the 11th, and I only pay attention on even numbered days.
RomanH
[ QUOTE ]
[ QUOTE ]
Paul,
[/ QUOTE ]
[/ QUOTE ]
No problem! /ubbthreads/images/graemlins/lol.gif
floyd
floyd
Thanks for the replies. we dont have emissions here in our county, yet. So, I think for now i will just run without it until I can come across a used one.
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
G TR6 TR6 air filter element replacements for stock housing Triumph 3
Got_All_4 TR6 69 TR6 air cleaner color Triumph 16
D TR6 76 TR6 Stromberg Air Valve Triumph 2
hondo402000 TR6 New Tires and Air pressures TR6 Triumph 9
E TR6 TR6 Cold Air Induction - Mixture Triumph 2
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
hondo402000 TR6 Air suspension for Tr6 Triumph 1
T TR6 Where can I get a front air dam for a TR6? Triumph 10
JoeC TR6 TR6 Dashboard Fresh Air Vent[s] Triumph 1
Hawk813 TR6 TR6 Brakes Triumph 4
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
