K&N filters for HD8 carbs
Digger
Does anyone know of a source for the K&N, or similar, air filters for the HD8 carbs used on a BJ8? I can't seem to find them, although I did find some for a Jag E-type, which I think uses the same carbs. https://www.dragtimes.com/Jaguar-E-Type-Custom-Air-Filter-Assembly-Part-64060.html
I have the engine out of the car, so I am unable to check the clearances. Any help or suggestions for replacement of the original filter would be appreciated.
Stretch
I go to my local car parts store that sells K&N filters and they order both oil and air filters I need overnight. You should have a parts store near you who can do the same.
They have them for the BJ8? I could not find them on their web-sight. Are they the pancake type the Coopers are? I was told they didn't have anything that thin.
Keoke
HI Stretch perhaps you could share the part number of the K&N Air Filters that you obtained to fit the HD8 carbs with the Forum. Fwiw---Keoke
GregW
I'd call K&N. The largest SU carb they list on their site is 1¾". I have called them in the past and found they have more than what they list on the site. Another option is one of the vendors that advertise here on BCF.
Not much of a fan of K&N; hold one up to the light, and you'll get an idea of how much filtration they'll do. They will keep out cats & dogs, but maybe not so many little insects.
Several years ago, a BMW enthusiast compared their claimed flowrate against the stock paper gaskets, and clean for clean, they were about the same. Sure, maybe at 150,000 miles the K&N will flow more air (and debris) but most of us will have changed our paper elements several times by then.
In the case of the Healey, you have to wash and re-oil the stock filters, so why buy aftermarket filters that require the same maintenance?
Just one man's opinion.
Michael Oritt
I have the SU FIlters pictured in Greg's post on my wife's 3000 and while they look nice I don't think they are anything special--just kind of "dressy". and they match the red Unilite and spark plug lines that are also installed!
I have a CAB on my 100 with a modified DW filter and foam stuffed up into the nose of the intake line so that it is accessible/cleanable simply by reaching into the wheel well.
I use a thick K&N on my Elva race car and think their product is the best. It is more durable and I always have a spare set cleaned and oiled and ready to install each time I service the engine after each race event.
In all cases with oil-type filters regular cleaning and light oiling is the ticket. I once removed the filter from my 100 when I was travelling out west and washed it--it was quite incredible how much dirt it had captured, all of which otherwise makes its way into the egine and causes wear.
Michael Oritt
"Not much of a fan of K&N; hold one up to the light, and you'll get an idea of how much filtration they'll do. They will keep out cats & dogs, but maybe not so many little insects."
Randy--
Now there ya go being wrong again!
MarkA
The K&N filters available for the E-type don't have the correct offset for correct fitment. I also believe the ones I have seen were a little too tall.
I also looked into taking the 1 3/4" version and opening it up. Didn't have enough material to get the correct offset for the front carb. K&N said they would ship me blanks for the base and I could cut my own, ... but then I just cleaned the originals and am waiting for a better solution.
Mark
B
BUNDYRUM
Hello GBPatterson, I bought my K & N filters from K & N. One was a 1 3/4" that I opened out to 2" diameter, the other was a blank that I machined to suit. I had to offset the mounting holes so it would fit onto the front carb and clear the shroud. The thickness of the filter is 1 3/4".
Hello MarkA, this is exactly as you described, they work just fine.
Best regards,
bundyrum.
I once negotiated to have some K&N filter kits for HD8 carbs custom machined by Advanced Performance Technologies (https://www.aptfast.com/). I worked directly with the owner, who built a prototype with the front filter offset as required by the front carb (I sent my original filter to him for use as a pattern). I 'advertised' to the healeys mailing list and had probably 20 people ready to buy. APT sent me the prototypes, along with some really nice billet stub stacks. I installed the filters and stub stacks and provided feedback to the owner of APT about fitting, mounting, etc. Then, the owner's wife was in some kind of serious accident--car, I think--and he became increasingly difficult to contact, eventually not returning my emails. I had to notify all the people who wanted the kits of this unfortunate failure.
Maybe if enough people contact APT saying they heard about this kit and want one he'll reconsider.
steveg
I bought mine from Moss a few years ago. They are the 1-3/4 type
The front one was hitting the bodywork so it was necessary to rework the inner plate to offset it right next to the carb dome. This gave 1/4" clearance or so between the air cleaner and the bodywork.
I prepared a drawing which is here:
https://www.healey6.com/Technical/Werner/Installing%20K.pdf
Stretch
I am using the K&N E-3180 filter element for my BJ7 (1.75 in. height). I am unaware of a K&N assembly/filter made specifically for the HD8 carb.
B
BUNDYRUM
Hello GBPatterson, I removed my front air filter to day and the hole is 1" offset from center.
Best regards,
bundyrum.
re: 'If you are using "after market" air filters, where do you put the hose from break servo?'
I left it going into the intake manifold. I routed the crankcase vent hose into a PCV valve, also going into the manifold.
If your BRAKE vacuum servo hose is routed to the air filter, you must have an incredibly hard BRAKE pedal.
B
BUNDYRUM
Hello tahoe healey, you attach it to the piece of tube you had welded to the filter backing plate.
Best regards,
bundyrum.
Y K and N Filters for HD8's Austin Healey 3
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
Writer2022 GT6 Overheating after fitting air filters Triumph 4
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
tahoe healey Cooper Air Filters Austin Healey 7
T Spin-On Oil Filters Austin Healey 19
S TR2/3/3A restore my original air filters Triumph 5
Patrick67BJ8 Water filters Austin Healey 16
N Air filters Austin Healey 5
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
JFS TR2/3/3A Weber Air Filters Triumph 7
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
doc50 Wanted H2 Air filters for 73 Midget Spridgets Classified 0
PeterK TR4/4A DCOE air filters Triumph 5
L K&N filters on 100/6 1959 Austin Healey 6
B Welch air filters Austin Healey 5
F What to do with breather pipe as my new air filters have no connection for one? Austin Healey 31
T General Tech NOS Paper Air Filters, Shelf Life Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Need help with oil filters Spridgets 1
T TR2/3/3A Question on paper air filters for TR3 Triumph 3
M TR4/4A What modified carby air filters to use on my TR4 RHD. Triumph 19
T TR2/3/3A How can I bend TR4 air filters to keep them from hitting fender on TR3A? Triumph 1
PatGalvin TR2/3/3A TR3A After Market Air Filters? Triumph 31
Gearhead_Garage Big Healey Air Filters Austin Healey 22
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
andrea Azir filters Austin Healey 5
Lin K&N Air Filters for SU HD6 carbs Austin Healey 14
D TR6 Air filters Triumph 2
S Best air cleaners/ filters for street Spridgets 8
Zitch TR4/4A Can I use these Paper filters on my 63 tr4 Triumph 2
G K&N air filters for 1967 BJ8 Austin Healey 6
B oil filters Spridgets 7
fad64b TR2/3/3A TR3 Air Filters Triumph 7
J Spin On Oil Filters Triumph 5
A Anyone have air filters to sell? Triumph 5
A TR2/3/3A What air filters for '59 TR3? Triumph 17
Boink Fuel filters... locations, types... Spridgets 8
S Spitfire Spitfire Fuel line filters Triumph 7
H filters inside of BJ air cleaner? Austin Healey 24
scoutll A Series Spin On Oil filters?? Spridgets 8
I Stock bugeye air filters Spridgets 9
K SU Carb Mix...Air filters on? Triumph 4
