HD8 Idle Adjust Screw
Goldie
I was trying to adjust my HD8 carbs on my BJ8. One of the fast idle adjustment screws was the wrong size and would not thread down through the plate. The threads were close but not correct. What is the thread count and type of screw needed? Is this a British style screw? I am trying to order from Moss. It is shown as available in the Moss catalog but they show the order as pending. Other sources?
That explains why I was having some of my idle problems when the engine was cold. Carb for cylinders 4-6 is correct.
Platinum
I'd be on th' blower to Joe Curto.
Platinum
Platinum
I think I would go to the company that made the carbs and buy there.
I'm not disagreeing, just that New York is a ~lot~ closer and British Superior buy & supply the genuine SU parts. Shipping cost & time considerations kinda offset BritSuperior's markup. Call them and ask if they have the part in stock first!
WHT
Hi Goldie,
I rebuilt our carburetors using the rebuild kit Joe sells; and all the parts were excellent quality and fit well.
My understanding is Joe supplies the SU rebuild parts that are sold by Moss and I would definitely call Joe and discuss this with him. He is a great guy and always happy to help people. He is your best source for SU information IMO.
Regards, Bill
G
Goldie
I did contact him and found him to be very responsive and extremely helpful even though I was looking for a very inexpensive part . Turned out Moss had the screw I needed but were very slow posting they were going to ship them. I started searching for alternative source in case they were back ordered. He has lots of small HD8 parts that Moss doesn't carry. I will use him when I need to rebuilt my carbs.
steveg HD8 high idle aggravation Austin Healey 11
M New Member with an HD8 Carb Question Austin Healey 1
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
J Wanted HD8 SU carb set Austin Healey Classifieds 6
wangdango Colortune for HD8 Carbs? Austin Healey 55
B mysterious leaking of SU HD8 Jaguar 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
D S.U. HD8 Carburetor Drawing Austin Healey 6
S Float valves for HD8 - Grose Type Austin Healey 20
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
D Rebuilding the SU HD8 carbs Austin Healey 24
pkmh HD8 SU Carburetor removal Austin Healey 48
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
D K&N filters for HD8 carbs Austin Healey 26
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
BOBBYR HD8 Carbs Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
A BJ8 SU HD8 carbs for sale Austin Healey 0
J HD8 shaft bushing & king pins. Austin Healey 6
R Setting up HD8 carburetors Austin Healey 6
Lin HD8 carbs Austin Healey 2
