T-Series MGTD Front suspension and Swivel / King pins
EinsteinsDad
I am rebuilding a 1953 MGTD:
I am tring to replace the swivel pin which is pressed into the stub axle in the front suspension. I have successfuly disassembled the left side completely. I have gotten the steering lever arm out of the left side unit. I have two new swivel pins (left and right).
1) What is the best way to press in the new swivel pin? It is very tight. Is it just pressed in? What is the best tool to use and should it be lubed to assist in assembly, or do I turn the pin to reduce its diameter?
2) What is the best way to separate the other existing swivel pin from the stub axle? Again, what is the best tool and technique?
Any insight will be appreciated. Thanks.
David
1953 MGTD /ubbthreads/images/graemlins/hammer.gif
Steve_S
I haven't gone this far into the suspension on my Y-Type yet (same as TD suspension) so I can't be of any help, sorry! The link Bob gave would be a good place to post your question. Good luck!
EinsteinsDad
EinsteinsDad
Thanks. I will post there too.
Steve_S
That suspension is looking a bit too clean. Get that thing together so you can take it out and get a bit of dirt on it! /ubbthreads/images/graemlins/wink.gif
P T-Series MGTD Front Brake Drum Removal? MG 9
D T-Series MGTD Oil Leak? MG 2
R T-Series Valve gap for an MGTD 1953. MG 5
B T-Series Battery replacement mgtd MG 2
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
PAUL161 T-Series Custom MGTD MG 5
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
A T-Series MGTD oil pump bypass valve MG 0
A T-Series Mgtd oil pump alterations MG 2
P T-Series Lea-Francis MGTD MG 10
P T-Series MGTD - before and after MG 3
H T-Series MGTD Christmas Ornament MG 1
vickxxx T-Series 1952 MGTD spark plugs. MG 4
bfitz T-Series 1951 MGTD oil pressure question MG 5
vickxxx T-Series turn signals for MGTD MG 5
smaceng T-Series Does a 1952 MGTD use a 12V battery? MG 4
richberman T-Series MGTD suicide door lock lever orders MG 0
B T-Series MGTD brake shoes. Are there leading and trailing shoes? MG 1
F T-Series MGTD Factory Original Color MG 5
justin_mercier T-Series Dimensions of an MGTD windscreen? MG 1
S T-Series MGTD SEAT MG 1
rick_ingram T-Series Wanted To Find - MGTD #1091 MG 6
mountainman T-Series MGTD Top Insutlation MG 4
T MGTD -- Columbus Spotted 0
M T-Series soft plug 52 mgtd MG 3
mountainman T-Series MGTD What is it worth MG 2
G T-Series MGTD Steel wheels MG 3
B T-Series Pic of my MGTD MG 8
C T-Series Need a MGTD Steering Wheel MG 5
G T-Series Newbie '51 MGTD MG 2
P T-Series MGTD Fuel Pump Pressure MG 2
Steve P. T-Series Which Volvo engine fits in an MGTD? MG 40
Hedgehog T-Series MGTD sighting MG 3
CCURTISS T-Series MGTD/TF Carbon Release Bearing Question MG 3
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
J T-Series MGtd looking at one Sunday-need some help MG 4
T T-Series MGTD Supercharger MG 2
rick_ingram T-Series MGTD Crankshaft MG 6
6 T-Series MGTC / MGTD Period Correct Carb/Intake Systems MG 8
Steve P. T-Series any MGTD's with custom bodies out there? MG 7
W T-Series MGTD rear oil seal leak MG 7
G T-Series Dropping the oil pan on my MGTD MG 1
beaulieu T-Series MGTD engine/gearbox same as other MGs? MG 21
beachbumbarry T-Series MGTD anti-sway bar MG 4
beachbumbarry T-Series MGTD basket case MG 16
T T-Series smiths or arnolt heater installation in an MGTD MG 1
martyc T-Series My MGTD-related Web Log MG 5
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
