TR6 TR4a vs TR6 fulcrum pins [was TR4a shims]
Re: How many shims on your TR4a
I have a couple on one side, not to get it correct, but just to get it even between the two side. I'd need negative thickness shims to get it right (or try to shim out the cross tube, I guess).
Hi Darrell - thanks for the response.
So you are neutral to negative chamber even without shims? Huh. I'm pretty positive with two shims still.
The ball joint #10 is centered / that is not direction installation sensitive, correct?
If I managed to reserve the upper arms #2 and #3 would that result in the positive camber?
And #1 would also have an impact if I mounted it "backwards", correct?
Actually - #2 and #3 would just mess up vertical alignment of the suspension/shock etc so I think I may have put #1 in backwards.
Yes, the bottom of my tires are about 1/4" wider than the top. Actually one side it like that without shims, the other is vertical, but I shim it out to match (figuring that matching side to side is more important).
I believe that is true.
I don't think so, at least not directly. It would cant the link forward (and might be hard to do, since the lower trunnion is canted).
Yes, though I'm not sure you can, I think it would partially block the top shock mount.
I should also add that most of my lower brackets have been replaced, so there position may not be exactly as they left the factory.
You can put it in backwards, and it will mess your alignment up a lot =D
So it would seem Justin! What a chuckle head I am.
I'll check it in the AM, pretty sure that is what I did.
Trying to think how much of this needs to be disassembled to turn it around the right way.
If you support the lower link (jack or stand), you should be able to undo the two bolts through the top ball joint, and the bolts holding #1 down. Do both sides, and you can flip the upper arms over and swap sides, so you don't have to remove the arms from #1.
OK guys - double check me here. Which way does the fulcrum pin curve face - towards the engine or towards the outside of the car? The curved section currently faces the engine now.
Hi guys - so I think I may have found something here.
Justin - I believe that is correct for the TR6 but NOT for the TR4a. I believe that the curved side faces out on the TR4a.
There is a large difference in offset in the fulcrum pin, and having the curve face out would adjust out my too positive camber.
As installed on the car - which I did not remove or even check since I assumed it was right and matched by TR6 - my fulcrum pins had the curve towards the engine. Hence my inability to get the camber correct.
Yep - just finished switch the orientation on the driver's side and I have correct camber on that side now.
Someone please double check me here but there are two good reminders here;
1) Don't assume that anything from the PO was done correctly.
2) Don't assume that the suspension detailed between the TR3, TR4, TR4a and TR6 are all identical.
Tom,
2 out of 3 TR4A front suspensions prefer curved side facing the engine and those are the 2 that I'm pretty sure have not been touched. Of course the one that I restored has it the other way with curved side facing the wheel which might explain why I had issues getting the darn thing aligned! At the time I chalked it up to some issues I had with the crossbrace bar and the frame but now I'm thinking that I assembled it incorrectly.
Don't you have 2 TR4A's also?
Scott
Hi Scott - I'll have to check the earlier TR4a and report back, but there is a chance that it has been messed with as well.
Tom,
Trying to find other references to this and found the following quote from a post on the TR Register forum.
"In my TR4A it was mounted in the way TR6 does (fulcrum pin DOES NOT follows the natural curve of the top of the turret) . When it was assembled again (after my frame off restoration) it was mistakenlly made like the older version (TR4). Since I got problems with camber (too negative) I am assuming the former position is correct and so I am changing it back during the next weekend."
There are some more posts there as well about this which all seem to indicate that that TR4A-TR6 are all the same.
Is there anything else that could be causing the postive camber?
Scott
Hi Scott. Funny - my Googling supported the opposite conclusion. People said it changed on the TR5/250/6 due to the extra weight of the engine (which kind of makes sense).
In any case the only way I could get close to neutral camber was the have the curve facing outwards. Could just be this car but now I'm really curious!
Well, now this thread is making me question the whole thing even on my TR4. According to Roger Williams the 4A had it with the curve towards the engine, and kept that way through the TR6. The TR3 had it outward towards the wheel. And Roger notes than on the TR4, it might be either way - his writing style isn't very direct, but it appears the change in pivot orientation may be when they went with the TR6 style upper ball joint. Confusing.
Hi Randy - some pegged the cut over at the TR4 not TR4A, others at the TR5/250/6. I'd be willing to believe that the extra weight of the six cylinder engine could prompt a change.
I think the whole thing may be further thrown off by ball joint changes, and of course this will be car specific.
All I can say is that on my particular TR4a there is no way that I could get to a proper camber angle with the curve facing inwards.
I'll check the other TR4a tonight and report back, but as mentioned above who know if that car is correct.
Tom,
I didn't think there was that much weight difference between the 4-cylinder and the 6-cylinder?
Scott
It was common to flip the upper fulcrum around to decrease camber (increase negative camber) in race cars. But AFAIK (which isn't much), the 6 and 4A (not TR4) have identical front suspensions except for the two pin lower inner fulcrum brackets used in the 6. The only difference there is the extra mounting pin for strength. Same rack, arms, ball joint, tie rods, et c.
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
Sarastro TR4/4A Puzzled about TR6 door seals on a TR4A Triumph 7
Rut TR4/4A TR4a or TR6 top frame? Triumph 4
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
Scotsman TR4/4A Can the TR6 exhaust go on a TR4A Triumph 5
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
T TR4/4A Anyone have pictures handy of TR4a with TR6 steel rims? Triumph 13
K TR6 Differences in Chassis on 67 TR4A and 73 TR6? Triumph 8
K TR6 Are TR6 dasboards the same as TR4A? Triumph 5
T TR6 TR4a IRS vs TR6 handling Triumph 20
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
T TR6 SU or TR6 ZS carbs for my '66 TR4a? Triumph 18
M TR6 TR4A on a TR6 Frame? Triumph 19
rlich8 TR6 TR6 fan on a TR4A Triumph 3
T TR6 Differences between TR4a and TR6 convertible tops Triumph 14
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
KVH TR6 TR4A/TR250/TR6 Triumph 5
T TR6 TR4a and TR6 gas tanks interchangeable? Triumph 10
T Wedge TR4a, TR6 and TR8 seat webbing's interchangeable? Triumph 2
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
TR4A_IRS TR6 Will all TR6 seats fit in a TR4A? Triumph 11
T TR6 Moving TR6 gearbox to TR4a - any issues? Triumph 5
T TR6 TR4A sway bar same as TR6? Use same bushings? Triumph 12
G TR6 TR4A & TR6 Marriage? Triumph 26
fad64b TR6 TR4A - TR6 clutch pressure plate??? Triumph 9
Paulus TR6 Changing a TR4A fan to a TR6 fan Triumph 3
B TR6 TR6 wheels fit a TR4A? Triumph 5
kindofblue TR6 TR6 seats in a TR4A Triumph 3
T TR6 Will a TR6 4 speed fit a TR4A Triumph 7
PeterK TR6 Installing a TR6 M/C, servo setup in a TR4A Triumph 5
T TR4/4A Triumph TR4A 1965 price Triumph 8
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
