TR4/4A Possible to put TR6 seats in a TR4A
blhazzard
Member
Just a quick survey to see if anyone has installed TR6 highback with headrest seats in a TR4A ?
Looking at the seat rail set for mounting.. (Moss: 801-430 $78.99 SEAT RAIL SET (3 pcs.)) is the same part
number for the TR4 (TR4 from (b)20877CT - 4A) and TR250/TR6.
I am looking for a more comfortable seat with a higher back and head rest since I know that roll bar is going to hurt if I ever get rear ended...
Is this as simple as buying replacement TR6 seats ?
I am planning to keep the refurbed TR4A seats for show purposes.
Any comment on these ? (other than their cost).
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=126967
charleyf
YES, it is doable. I have two TR4's and both of them have the TR6 high back seats. I did it mostly for the reclining feature of the seats. One car has a red interior and the TR6 red seat covers match perfectly. At least the ones from TRF do.
The second TR4 has the midnight blue interior so I had to special order the midnight blue covers through TRF. I used the stock seat slides from TRF in both cases.
Charley
charleyf
Yes, I bought the vinyl seat covers and the foam kits for both from TRF. I ACQUIRED THE FIRST SEAT SET WITH A TR4 parts car. The second set of seats I bought on eBay. I had a local shop assemble the first set as all there was were the frames and strapping. The second set were complete when I bought them. So I disassembled them and built the new set myself. I have no experience with the Moss covers.
Charley
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
