TR6 Possible TR6 Project ? ?
Norton47
I emailed this guy the other day. His brother ran it under a Chev Blazer and the front of the hood and fenders are a bit mashed. Wiring issues and such. I have more photos that he sent if someone is interested.
This one is down in Vancouver WA.
https://portland.craigslist.org/grg/cto/1962173666.html
Has thrust bearing issue with the crank. Nice guy to talk to. Over the phone it sounds like not much rust.
G TR6 Possible TR6 project? Triumph 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
smaceng TR6 Possible Purchase of a TR6 Triumph 21
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
bcbennett TR6 TR6 Door adjustment...possible? Triumph 1
A TR6 Goodpart camber adjusters--possible problems?[TR6] Triumph 6
Brosky TR6 TR6 Front License Frame - a possible market? Triumph 30
jmayled TR6 Possible rebuild of SU-HS6 Carbs for TR6 Triumph 26
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
G Possible TR find Triumph 10
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
