Can't be possible can it?
tomshobby
Shirley and I took our Midget for a drive yesterday. I filled up when we left and zeroed the trip meter. We drove 112 miles most of which we were running 65 to 70 mph. When we were getting ready to return home I filled up until the gas was up in the fill tube to where I could see it. That took 2.2 gallons. Car ran great all the way and the engine temp was about 2/3 the way to the "N" on the gauge which has been the normal temp for our car.
That makes it 50.9 mpg.
Boink
Bronze
Wow. I've never gotten over 35mpg with my 1275 (1293 as it's 20 over with dual HS2s), but then I often drive it hard. Heck, I usually get under 25mpg!
JPSmit
seems high to me also - were you driving downhill?
nomad
Tom, 112 miles aren't really enough for a good test I would guess. Just a little difference in the way the car was leaning or how full you got it could make a difference. Still Bill M, who should be along any time was averaging up into the mid 40's during the Midget 50 trip and Frank C averaged high 40's when he drove out to LoTO from NJ. My Datsun engined Midget regularly get's low 40's at 2 lane speed's but the last time I though I had averaged over 50 I realized the two gas station's weren't level at the pump's and sloped different way's.
Try it again and let us know!
Kurt.
tomshobby
tomshobby
Thinking back, we were on 4-lane roads nearly the entire way. The road was quite level with no real hills and we did keep a steady speed with only a couple stops for traffic lights and one for lunch. We also had the top up if that makes any difference.
nomad
Tail wind???:eagerness:
Kurt.
Bayless
Down hill. Both ways.:popworm:
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
