TR5/TR250 Is this even Theoretically Possible? [Brake Question]
glemon
So I went to take my car to an event on Su day night and I notice the brakes are making a weird whistling or sucking sound when I push the pedal. I check and the fluid is almost dry in the master for both the front and rear brake reservoirs.
Didn't have enough spare brake fluid to refill (Dot 5, flame away!) and no parts stores open so I refill Monday kind of check everythi ng out, no pools of fluid anywhere or obvious leaks.
Pedal feels good, high and firm, doesn't drop with sustained heavy pressure so I go for a short careful drive. I have filled it tonthe very lip of the separator between the two reservoirs in the MC (same set up as a TR6) so pretty easy to tell if any appreciable drop. No apparent fluid loss.
Check again today, still topped up, go for a couple more drives, stomp on the brakes where there is no traffic and I don't have to stop. All good. No sign of losing fluid.
Here is the kicker, I have a set of air filters with a vacuum hose to the pcv system, and a set of trumpets which I put on occassionaly and let the tube hang. Could there be some weird interaction with the PCV (stock round valve like used on TR and other similar era british cars) and the brake booster wherein it was sucking fluid out of the master cylinder when I didn't have the system all hooked up, or is that just crazy talk?
I did order a master cylinder rebuild kit (it isn't that old) and will probably tear into it and see what I can find out regardless.
TexasKnucklehead
When I had DOT5 fluid mysteriously disappearing from my TR6 clutch reservoir it turned out to be in the thick carpeted floor mat, and the padding under it. It seems the master was leaking and dripping down the pedal before dripping onto the mat. When I hosed the mat with water, the fluid was obvious.
It seems odd that the brake master would do the same thing, since it has two isolated reservoirs. It also seems unlikely to be vacuum related, since no fluid should be in the booster -unless the master is leaking into it.
TR3driver
Great Pumpkin - R.I.P
Might depend on the car; but a typical vacuum brake booster is designed to withstand essentially hard vacuum (more than the engine can possibly generate). Likewise, the MC has to contain 1000 psi or more, so 15 psi of vacuum is nothing to it.
IMO you're going to find multiple failures, probably both MC and booster are bad and the booster has a bunch of fluid in it.
Might be a good idea to leave the vacuum line disconnected if you have to drive it before rebuilding or replacing them; as one of the supposed dangers of DOT 5 is what happens if it gets sucked into the engine and burned. But better yet don't drive it, as you may be on the verge of a sudden, total hydraulic failure. BTDT, burned the T shirt!
glemon
glemon
Randall, yes, you are probably right. The booster is original, kind of surprised it has lasted as long as it has, I will take things apart when I get a chance and see what I can figure out. I don't have much time to drive it or work on it now, major home projects starting including a new garage build.
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
