Possible bearing problem
Tomas_Norway
My BN-7 have a noise that sounds like "whoosing" sound that is coming from the the gearbox or the rear of the engine. (It is hard to describe a sound in writiing.) To me it sounds like bearing noise, but I am far from an expert in this...
The noise disappears when the engine is under load, but is there at steady, slow speeds up to 35 mph, and at idle. It is not that loud, but can easily be heard. It has been there since i put the engine and trans together, but I think it has slowly been getting worse.
Does anybody have an idea of what it can be?
dancrim
You could try to narrow it down by stepping on the clutch pedal. This will
pretty much rule out the transmission. Also, could it be the clutch throw uot berring? Adjusted too tight?
bighealeysource
Bronze
Hey Tomas,
Sounds like the same noise I would get from my BN6 rear end when not accelerating or under load. Turned out to be the pinion bearing. Under load no noise, but if not would be a distinct whining noise. Not bad, but I noticed it and what was aggravating, only came on after I replaced the pinion oil seal. Think I did not get the nut torqued tight enough and allowed the bearing to just barely move to produce the noise when not under load. Good luck finding it, know noises like that can drive one nuts.
Regards,
Mike
T
Tomas_Norway
Thanks for the advice.
Stepping in the clutch pedal does not change anything. I admit ignorance as I did not know that the bearing was adjustable, I will look it up in the manual. But the clutch does "take" at normal pedal travel, so not sure if this is the fault...
TimK
Maybe a worn pilot bushing?
with the car idling in neutral, rest your ear on the shift knob; does it lead you to believe the noise is emanating from the gearbox or elsewhere?
A similar test can be done with the rear wheels safely lifted clear of the ground and "running" at low speed in 4th (direct) gear.
Using a long shank wood handled screwdriver makes an excellent listening device too. place the tip on various parts of the engine, from front to rear, with the handle touching your ear__do stay well away from the fan!
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
