TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb?
TuffTR250
I acquired a couple of SU H6 carbs (AUC878) but unfortunately they are both back carbs and therefore neither of them has a vacuum advance port. Is it possible to drill a hole and tap the hole in one of the carbs and mount a vacuum port? If possible, does anyone have detailed specs on where the hole should be drilled and detailed instructions on how to go about doing this? Also, where would I get the proper fitting to screw into the carb? Thanks for the help!!
Regards,
Bob
TR3driver
Great Pumpkin - R.I.P
Then you'll want the fast idle cam; and the choke arm; and a longer throttle shaft ...
I believe the casting boss is there, but I've never tried drilling for the advance port. You'll need to drill all the way through with a small drill, to create the port into the carb throat. It needs to be carefully aimed so the opening is just in front of the throttle plate when the throttle is fully closed. Then you'll have to drill partway with a larger drill, and tap for the fitting. The factory fitting appears to be available from TRF, their PN SUAUC4490. But it used a strange thread into the carb body and I'm not sure where you'd find a tap for that.
T
TuffTR250
Thanks Randall!! And thanks for the TRF p/n! Any idea what size holes needs to be drilled? Would 1/8 be right for the hole that goes all the way through? If no one knows the size hole for the fitting, I may be able to call TRF Tech Support and find that hole size. I hope TRF Tech Support would also know what the thread size and spacing is.
Regards,
Bob
titanic
The hole for the port is quite small, about .041" (#59 drill), at least on the HS6 carb I measured. It may be easier to find a front carb body.
Berry
TR3driver
I just checked an H6 body, and it appears to be between .040 (#60) and .041. The #60 went through easily, the #59 wouldn't go without force. I agree about finding a front body.
titanic
Any ideas as to why the port hole is so small? My guess is that it acts as a restriction to dampen the movement of vac advance unit.
Berry
TR3driver
My guess would be more along the lines of not disrupting throttle operation, but that's just a WAG. A bigger hole would allow air to flow into the hole on one side of the throttle plate, and out on the other.
poolboy
I don't think the hole, large or small would allow the carb to suck air into the mixture on a continuous basis...unless there were a hole in the Advance (or Retard) module's diaphragm or a loose fitting on the end of the vacuum hose. As to the size of the hole in the carb's throat, it must have been figured out by taking the Bernoulli principle into consideration..since the speed is greater in the narrower pipe, the kinetic energy of that volume is greater.
Read more: Bernoulli's principle | Infoplease.com https://www.infoplease.com/encyclopedia/science/bernoulli-principle.html#ixzz2ovsZEvHf
TR3driver
Ok, sorry, I should have written "would allow fuel/air mixture to flow into the hole on one side, and out on the other". In other words, it would form a throttle bypass, only when the plate was over the hole.
And since the air, er, fuel/air mixture in the small tube is essentially stationary (for a given throttle position and intake vacuum), I don't think Bernoulli applies.
poolboy
Yeah, you got a point there about the movement or lack thereof of air in the tube, Randall.
There must have been some consideration of some Law of Physics in determining the diameter of that hole, though.
T
TuffTR250
Randall, could you please do me a favor and measure exactly how far the center of the small hole is from the very back edge of the carb? i.e. the back being the face of where the carb mounts to the manifold. Thank you!
Regards,
Bob
TR3driver
I get .940" to the edge, so .960" to the center. Give or take a thousandth or two, I just measured with calipers.
BTW, check out eBay auction 161183567311 It'll probably get run up later on, but right now it looks like a deal.
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
