TR2/3/3A Is it possible for an intake manifold gasket leak....
mastaphixa
Bronze
I can't come up with a scenario that would work that way.
mctriumph
Did you get the head magnafluxed???White smoke is coolant in the combustion chamber.
There will also be bubbles in the radiator.
Mad dog
K
karls59tr
Bronze
Mad dog
Did not do that. The issue is a few hairline cracks on the block at a rear head stud. I installed a new head gasket anyway but it looks like it did not hold? I have a spare lock but it's a big job to tear everything down and do a rebuild. I know about block stitching and welding.This goes against my mechanical nature but I might try a last ditch effort just to see what happens and get one more summer drive before the tear down. Will get the head skimmed then I plan on V-ing out the tiny block cracks,cleaning everything out,installing JB weld (ya I know I hear everyone saying it wont work) loading up the area with red high temp RTV and installing a new head gasket with lots of copper gasket spray. Might even try Randall's 23 AWG wire trick on the gasket What have I got to lose? This is a true story: Years ago I had the bottom end of the motor rebuilt at a shop. A friend and I went to install the cylinder head and I noticed 2 hairline cracks at the rear stud. We loaded that area with RTV and installed the head. Drove the car for 20 years with no problem! Guess those cracks finally got a little bigger. What the heck I'm going to give it a shot.:smile:
CJD
I may be confused...is the white smoke coming out of the tail pipe or from under the intake?
K
karls59tr
Bronze
Under the intake only. Good compression in all cylinders.I don't think I am getting coolant into the cylinders.I think it's a head gasket leaking coolant to the atmosphere rather than leaking internally? I can't see any white smoke coming out of the rear of the head where the possible block hairline cracks are....cant feel or see any leakage there but looks like at some point there was some rusty residue on the block there. I suspect a gasket leak underneath the manifolds but I just can't make out where because of the smoke/steam.....maybe if I pull the manifolds I will see evidence there. I did put a pressure tester on the rad set at 4 psi and it was holding with engine not running.Next morning pressure had leaked out. Dont know if that's normal for a pressure tester to hold overnight or does pressur just dissipate over time?
CJD
You must have one of these issues:
1) bad head gasket.
2) Warped head or warped block in the area of the steam.
3) Cylinder liners are sitting too high, so that the head cannot seal the gasket against the block under the intake.
4) A cracked head or block in the area of the steam.
You will notice none of these possibilities are at all related to the 2 cracked head studs. The cracks around the head studs will be sealed by the head gasket, but coolant will make its way up the stud, around the nut, and into the valve area of the head.
K
karls59tr
Bronze
In regard to 3) .....what issue was Randall's thin wire soldered to the head gasket trying to solve? ....wasn't it that the liners were sitting too low? Well I'm going to pull the head and see what I can see. I had never done that before. It should go easier the second time around.:smile:
mctriumph
The most deadly cracking is in the head around the valves.The block crack you describe
is not a serious problem in most cases as it is a dead end 98% of the time. My bet is the head
is toast.
Mad dog
CJD
Randall's technique was to ensure the head gasket sealed well with the liners. He recommended it for the larger bores and did it on all his rebuilds, not just those with lower liners.
Copper is an interesting gasket material. If in the dead-soft state, it compresses well...but it also can flow with heat and time. When I was into RC model airplanes, the little high compression engines used solid copper gaskets. More than once I had an engine loose compression, and when I removed the head, the copper near the exhaust had pushed out. It looked like it was made that way.
I think the gaskets we normally use are copper covered composite, mainly to help prevent the copper from creeping like a solid copper gasket does. Adding an extra copper bead around the liners should improve the "crush" and help the combustion seal.
K
karls59tr
Bronze
K
karls59tr
Bronze
I believe someone mentioned that the size wire used was 23 AWG. Does it have to be copper wire? I think he mentioned that soldering was not really necessary and that Super glue would hold the wire in position just as well.
CJD
I have never done the wire technique, but I would think it does have to be copper. It must be soft enough to crush into the gasket.
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
