Possible leaking rear axle seal
Lon_S
I was cleaning the rear breaks of my ’65 midget in preparation for a rebuild when I noticed that the right rear was far grungier and difficult to clean than the left. It also seemed to leak a lot of fluid when I first started to mess with it. The hydraulic line seems to be okay, which makes me wonder if the rear axle’s oil seal may be bad. My question is this: do I need to remove the right rear axle in order to replace the oil seal and o-ring?
Thanks!
Lon
G
Yes, the axle must come out and to change the axle seal, you need to pull the hud too. IIRC, once the hub is out, you need to drive the bearing out the hub to get at the seal. It's a really stupid design.
If it's just leaking at the outter flange, you can just change the gasket and o-ring.
p.s welcome aboard
Lon_S
Lon_S
Thanks! I'll have a friend some by that knows more about this than I and we'll see if it's the gasket or if I need to go all the way. Here's hoping!
Thanks!
Lon
BuggerAll
You have to pay attention to the lube you use, too. Some of the modern synthetic gear lubes are very slippery, so much so that they will leak past a new seal - had this happen with my racer and its double bearing hubs, even with speedi sleeves installed. Use a heavy (8-90-140) all mineral lube after you replace the seal.
jvandyke
it's pretty easy to do though, even if there is quite a bit to take apart
JPSmit
The general consensus is also that too much oil in the diff can cause this. If you fill up the pumpkin till it leaks out the hole, that is too much, you can put in less than that. If you stick your pinkie in the hole and reach down, it should just touch.
Lon_S
Lon_S
Nothing like the high-tech pinkie metric test! :smile: Good to know. I'm thinking of just forgetting all of this "is it leaking or isn't it" game and just replacing all of the axle bearings and seals. It seems to me that give how long it has been since this car has seen the road it couldn't hurt.
Thanks!
Lon
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
