TR2/3/3A Brake Problems - Possible Solution
mastaphixa
Bronze
The 1960 TR3A I have been working on exhibited excessive brake pedal travel after negotiating a corner. Much has been documented on this issue in several posts on this and other forums. The basic problem is caused by front stub axle flex which results in the brake pads being pushed back into the caliper during cornering. I know hard cornering in competition has brought this to light and is a known characteristic of the car. I can only surmise the 195/65/R15 tires might contribute to this behavior even when not cornering aggressively. I eliminated the usual suspects by making sure my rear brakes were properly adjusted and the front wheel bearings did not exhibit excessive play to no avail.
Pursuant to correcting this problem I ordered the Upgraded Aluminum Hub and Stub Axle Kit (661-318) from Moss. This is a new offering from MOSS so I was prepared to work through whatever issues I might encounter. No instructions come in this kit. The axle swap was a non issue and I was impressed with the additional material the upgraded axles had. The hubs presented several problems.
First, the studs installed in the hub are for steel wheels not wires, so if you are installing this kit on a wire wheel car be sure to get the correct studs for them. Second the dust/grease cap will not work with wire wheels as they will not fit under the splined extension. Moss pn 662-060 grease caps did work nicely. Third, after installing the hub on the axle, I found there was interference between the inside face of the hub and the upright. This may have been something totally unique to the car I was working on or not, but I was able to fix that problem by installing a .025” shim between the inner bearing of the hub and the upright. I modified a 1 ½ “x 1” x .025” stainless shim (obtained from Amazon) pn B006UHDJO by turning the outside diameter down to approximately 1.32” so it would fit inside the inner grease seal.
After these issues were dealt with, I can report the car no longer requires a second pump of the brake pedal when applying the brakes after cornering.
I contacted Moss to advise them of all of these issues and they were very responsive and interested in my experience. They’re feeling was that at the price they were selling the kit at, these issues should not be present and I agree.
One additional piece of information to pass along. The inner grease seals are provided in the kit, but no part number is given. They are a metric seal 35x49x6mm. SKF carries them under part number 562578. The bearings/races provided in the kit I received were in a box with Timken part number SET1202.
Steve Baker
TR3driver
Great Pumpkin - R.I.P
FWIW, TRF offers a spindle spacer kit that was developed by a long-time TR4 racer, and works quite well even with the stock hub. The only downside is that the bearing clearance gets set with shims rather than the nut position.
DavidApp
Hello Randall
Does that spacer kit from TRF require the up rated spindles or will it work with the factory spindles?
David
Snowkilts
Moss also sells the upgraded axle with the spacer kit. P/N 661-293. I installed this (with the stock hub) last year. I think it's the exact kit I got from Tony Drews ("Uncle Jacks Racing") for about $200 bucks less than what Moss sells it for.
http://www.tonydrews.com/Jack_Parts.htm
Edit: I bought it from Tony, not Moss. What I got looks exactly like what is in the Moss picture.
TR3driver
The spacer kit will work with the stock axles; although the upgraded axles are recommended for best effect. TRF P/N HP660 for just the spacer kits; HP661 for spacers and axles.
http://trf.zeni.net/TR6-TR250GB/191.php?s_wt=1920&s_ht=1200
(Although listed for TR6, the same parts fit TR3 from TS13046 (front disc brakes) onward, TR4, TR5, etc.)
PS, My apologies to Steve for hijacking his thread.
M
mastaphixa
Bronze
Randall,
No worries! I think what attracted me to try the Moss axle hub kit was not having to fool with shims, which I ended up fooling with anyway! It sure is nice to have the brake pedal where it should be all the time. There's usually several ways to skin a cat.
Steve
D MGB Brake problems MG 6
NardisCNC E-Brake Problems..... Spridgets 11
H MK2 Brake problems Jaguar 2
H Brake problems Austin Healey 16
Got_All_4 TR2/3/3A TR3 E brake problems Triumph 19
W Problems!! Brake line bleeding and leaks Spridgets 5
Phil73 Brake problems Triumph 14
BabaKahawa Brake light Problems Austin Healey 14
bigbadbluetr6 TR6 TR6 Brake Problems Triumph 6
T 1989 XJ6 Brake problems Jaguar 11
R6MGS MGB MGB brake problems MG 14
B TR6 TR6 Brake Master Cylinder problems Triumph 12
F Brake Caliper Rebuild Problems... Triumph 12
H Brake problems Austin Healey 5
MadRiver Brake bleeding problems Triumph 10
K any problems with brake fluid in the footwell? Austin Healey 5
K Brake accummulator problems Jaguar 2
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
