Phil73
Member
I've been struggling with a problem in my brakes for a number of months now. The symptoms are a soft pedal, pulling to the right under hard braking and a rattle in the front end over rough pavement (goes away if the brakes are applied).
A month ago I completed a full rebuild of both front calipers but that had no impact. I re-bled the lines to no effect. I also replaced the flexible lines a year ago.
Yesterday I attacked the problem again. I've pulled everything from the front junction forward out of the car. I plan to thoroughly clean and check all the lines. I'm also going to switch the flexible lines from one side to the other and see if the pulling move to the left side (unlikely but I might as well eliminate the question).
As I was pulling things off I got to thinking about the bearings. 15 years ago when I restores the car I cleaned and repacked them but they have not been touched since then. Wondering if the source of my problems might not be in the bearings causing the disk rotor to wobble slightly. I feel no play when I check the bearings by rocking the wheel but I'm not all that familiar with good vs bad bearings so I might be missing something.
Should I just go ahead and pull the hubs, clean/repack the bearings and put them back together? Anything in particular I should look at when they are off? Given that the bearing are at least 15+ years old (more likely they are 35+ years old) should I just replace them? Hate to sink hundreds of dollars into parts I'm not sure need replacing though. Like I said, not much experience messing with bearings so I'm a little blind here.
