T-Series Another brake prob. ?
Louis 52MGTD
I am working the bug's out of my 52 MGTD, I think I have my generator Prob. and my front break leak fixed, the prob. I cannot seem to fix is after a drive when I shut the engine off and cut the ign. sw back on the brake lights stay on until it cools down, like the next morning, the lights do go off when I cut the ign. sw off.
The brake is right at the top, I have read where it should have 1/2 " free play, I serviced the master cly, as the book says, I jacked the car up and went counter clockwise one clk on the adjuster, all 4 wheel's spin freely, no friction on the drums, should I go another click on the adjusters and see in I can get that 1/2" free play, or is my prob. some where else ?
I'm new to these MG's and know little about them, have only had it a few week's, I do enjoy driving it but I'm guessing the brake lights stay on .
Here's a pic. of the car.
Grantura_MKI
Brake lite switch could be bad. Brake lites are usually wired hot, meaning they should work with out the ignition switch in the on position.
Adjust the brake drums until they are slightly dragging and test drive and check to see if it pulls or remains in a straight line.
L
Louis 52MGTD
I did cut the ign. sw. on [motor not running] and the brake lights did come on, when I pushed the brakes on the brake lights went off and came right back on very fast, did this each time I put the brakes on.
With the ign. switch off, the brake lights do not come on when the brake is pressed. ???
should I just order a new switch and try that ? Louis
L
Louis 52MGTD
Brake light prob. back again?
The brake lights stay on after a short drive anytime the ign. switch is on. they are normal before I drive it, it does have a small amount of play in the brake pedal aprox. 1/2" to 1" [I would think normal] before you feel the brakes, but when I put it back in the garage after a short drive [4 to 5 miles] the brake pedal has no play, it is all the way to the top and the brake lights stay on with the engine off but the ign. sw on.
I changed the break light sw a few weeks back and adjusted the brakes by the book and thought that fixed it. the brake system seems to build up pressure when I drive it, but it bleeds off over night, in the morning the brake pedal has the right play and the brake lights work like they should.
I guess the next thing is to change the master cly, right ? and is that a very hard job ? Thanks for any advice.
BTW, it's a 1952 MGTD
mezy
Sounds like it could be a master cylinder issue not releasing the pressure in the lines.
try taking it for a run, then when brake lights are stuck on jack up each wheel in turn to check they spin freely,
if the master is not releasing pressure the brakes will bind.
L
Louis 52MGTD
I adjusted the adj. rod on the master cly. screwed it out from the M/C 4 or 5 turns, now the pedal feels a lot better, not as hard and up top as it was.
I drove it last night on a short drive to test it and the pedal stayed down about 2-3" like it should, it feels a lot better now, I will take it on a longer ride today, but I think that was my prob. the brake lights work like they should and are off when I pull into the garage, and the pedal does not stay at the top with a hard pedal.
This was my last attempt before I ordered a master cly. from Moss. I'll get back after my drive, but I feel it is ok now.
L
Louis 52MGTD
Just got back from my longer 2nd test drive, all is well :smile:. floor board and carpet are back in [although I could have done it with out removing it].
If your retired and getting board and want to renew your mechanical skills, just buy a 71 year old British sports car.
Since June I have repaired the frt. brake cly. leaking, the gen. not charging, the brake lights staying on and brake pedal at the top and building up press. when you drive, adjusting the clutch [the lock nut was missing] ,and several other small job's. But, now that their fixed, It was not work but kinda fun [hobby] and I have learned a lot about the car.
I love the sound of it and it's so much fun to drive.
Thank you all for your good advice. Louis
K TR2/3/3A Another brake bleed question....... Triumph 17
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
B Another disc brake question Spridgets 10
T TR2/3/3A another brake master cylinder question Triumph 16
RedTR3 TR2/3/3A Another TR3 Brake Question Triumph 1
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
T I added another TVR to the fleet. TVR 10
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
