BN2 Brake Drums
Gundog61
A year into our Healey, which was a resto started by my father in law, and finished by us upon his death. We decided to put new wheels and tires on this year, and in doing so the brake drums had been painted black, and from what I can tell they were silver from the factory. So I am going to sand blast and paint them silver. I just noticed that they are different in respect to, it looks like a 1/3 of the outside ridge has been remove maybe for balancing, or maybe they are not original and from different years.
Could anyone provide insight on this? Where they factory balanced and modified?
Thanks Todd
BobHaskell
Todd,
The factory didn't balanced brake drums. And they can have a lot of imbalance. Getting them balanced is one way to reduce the infamous scuttle shake. Allen Hendrix at Hendrix Wire Wheel balances drums. But he adds material, doesn't remove it.
Yes, the drums were originally silver. The same color as painted wire wheels.
FWIW, my BN2/100M--mostly original AFAIK--has had significant metal removed from the ridges; I've always assumed it was for balancing. The metal was removed very cleanly and, apparently, 'professionally.' I've always wondered what kind of machine/process was used as there aren't any grind marks or other evidence and I don't think this could be done on, for instance, a common machine like a lathe. If not done at the (wheel) factory, I'd be curious to know if it was done at/by dealers or others.
My car had horrendous scuttle shake with what appeared to be its original wheels; a new set of MWS wires and Vredesteins all but completely eliminated it. I had it out yesterday for a drive in the foothills; now, with no shake and rebuilt dampers, I can feel every crack in the pavement :LOL:
BoyRacer
I've balanced many rear brake drums on Healey 3000s. The most serious out of balance drums I've encountered took around 3 ounces to balance. Rather than add weigh to one side, I would slice off a portion of the rib (on the opposing side) that extends around the outside of the drum. To remove 3 ounces of weight takes a slice about 3-1/2 to 4 inches long. I used a good quality (not harbor Freight) bubble balancer. I use an angle grinder with a cut-off wheel.
MikeAH100M
My '56 had the same chunks of metal removed from the drums, but I still had some scuttle shake. Sent Vredestein tires and my rims to Allen Hendrix. He balanced and trimmed/trued the tires on the wire wheels. Result - no scuttle shake.
Gundog61
Gundog61
Thank you all for the responses. I am thinking that the drums had some type of rough balance from the drum manufacturer. I have a brand new set of wheels and tires from Hendrix waiting to go on. I needed to replace my hub extensions; one was really bad.
Allen Hendrix’s was awesome, and I enjoyed the conversations we had and learned a lot.
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
MikeAH100M Brake Issue on BN2 Austin Healey 4
S BN2 Brake Problem Austin Healey 1
D BN2 brake lines Austin Healey 6
Thomas591 Disc Brake conversion to BN2 Austin Healey 5
A BN2 Chassis Alignment Austin Healey 8
T 100 BN2 Possible Ignition Issue Austin Healey 10
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
H BN7 and BN2 Lengths Austin Healey 3
bighealeysource BN2 Master Cylinder Austin Healey 91
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
MikeAH100M BN2 Tight Steering Austin Healey 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
Guido36 9k-Mile BN2 at Auction Austin Healey 13
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
Guido36 BN1/BN2 Sidescreens Austin Healey 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
J BN2 Shift Lever Bushing Replacement Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
J 100 bn1/bn2 id Austin Healey 26
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
C Wanted 100/4 BN2 1956 Le Mans side windows Austin Healey Classifieds 0
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
A BN2 Boot Lid Austin Healey 4
P BN2 new wood steering wheel install Austin Healey 5
W Gear Lever Boot for BN2 Austin Healey 5
J BN2 shift bushing replacement Austin Healey 5
wangdango BN2 wheel cyclinders/replacement Austin Healey 1
