BN2 Boot Lid
ahmk3
Has anyone had luck with the Moss alloy trunk lid ? I would prefer steel, but haven't been able to locate a good usable, or repairable one. .. any suggestions. .?? Thanks
roscoe
The boot lid was the only significant part missing from my BN2 project when I brought it home years ago. I had a heck of a time finding one but finally did. Mine came from Bill Bolton and I'm recalling he gave me a choice between two and different prices depending. I do not know if he is still in business. I seriously doubt you will easily find one that simply needs to be stripped and painted. Most have the standard crack at the strut mounting point ( as mine did) but you have to figure if someone is parting out a car the boot lid is a prime suspect for all kinds of damage. You might try British Car Specialists in Stockton, CA. Maybe depending on the price for the aluminum unit you could buy one of those amazingly rusted out 100's you see on ebay once in a while and end up with a salvageable boot lid. Sorry not much help here.
HEALEYJAG
Call Healey Surgeons..they will be honest on the fit of theirs, if they stock them.. or they might have a used one..
A
ahmk3
Thanks for the advice, and the contacts... I have two different, two seat lids..,both very nice.. may just section the mint one...I know metal work,...just don't like working with aluminum. .... Thanks again...!!!
W Gear Lever Boot for BN2 Austin Healey 5
A BN2 Chassis Alignment Austin Healey 8
T 100 BN2 Possible Ignition Issue Austin Healey 10
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
H BN7 and BN2 Lengths Austin Healey 3
Gundog61 BN2 Brake Drums Austin Healey 5
bighealeysource BN2 Master Cylinder Austin Healey 91
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
MikeAH100M BN2 Tight Steering Austin Healey 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
Guido36 9k-Mile BN2 at Auction Austin Healey 13
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
Guido36 BN1/BN2 Sidescreens Austin Healey 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
J BN2 Shift Lever Bushing Replacement Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
J 100 bn1/bn2 id Austin Healey 26
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
C Wanted 100/4 BN2 1956 Le Mans side windows Austin Healey Classifieds 0
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P BN2 new wood steering wheel install Austin Healey 5
J BN2 shift bushing replacement Austin Healey 5
wangdango BN2 wheel cyclinders/replacement Austin Healey 1
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
P BN2 Walnut Steering Wheel Austin Healey 10
P Healey BN2 Distributor Question Austin Healey 1
Martinld123 Austin Healey BN2 oil leak at base of distributor Austin Healey 7
