BN2 Steering Box Leak
Gundog61
The first problem is, I believe, the wrong gear oil was put in the steering box. The lower seal is leaking and the oil is just running out of it. I have since put in the correct fluid and maybe it will be less of a problem.
My real question is Has anyone been able to change this seal without removing the box or doing a top end rebuild? After removing the Pitman arm, can the old seal be removed and replaced?
I've done it. The hardest part is getting the pittman arm off; I ground down a Harbor Freight ball joint puller. I made a couple seal 'pullers' out of some 1/8" steel rod on which I ground long, flat ends--like a long screwdriver blade--then bent about a 1/16" of the tips. I worked them in and was able to pull the old seal out, and tap a new one in. The correct seals are hard to find, aftermarket replacements are thinner so some pack two of them in there.
An alternative is to put a really thick oil/thin grease in the box. Corn head grease works and there are some really thick oils from Penrite and others. Search on 'Healey steering box leaks' on this forum for some info.
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
MikeAH100M BN2 Tight Steering Austin Healey 4
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
P BN2 new wood steering wheel install Austin Healey 5
P BN2 Walnut Steering Wheel Austin Healey 10
Bob_Spidell Belleville Washers in BN2 Steering Boc Austin Healey 9
MikeAH100M Steering Stiffness - BN2 Austin Healey 7
timbn2 BN2 steering column parts assembly questions Austin Healey 0
timbn2 Bent BN2 Steering Column Austin Healey 8
A BN2 Chassis Alignment Austin Healey 8
T 100 BN2 Possible Ignition Issue Austin Healey 10
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
H BN7 and BN2 Lengths Austin Healey 3
Gundog61 BN2 Brake Drums Austin Healey 5
bighealeysource BN2 Master Cylinder Austin Healey 91
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
Guido36 9k-Mile BN2 at Auction Austin Healey 13
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
Guido36 BN1/BN2 Sidescreens Austin Healey 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
J BN2 Shift Lever Bushing Replacement Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
J 100 bn1/bn2 id Austin Healey 26
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
C Wanted 100/4 BN2 1956 Le Mans side windows Austin Healey Classifieds 0
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
A BN2 Boot Lid Austin Healey 4
W Gear Lever Boot for BN2 Austin Healey 5
J BN2 shift bushing replacement Austin Healey 5
wangdango BN2 wheel cyclinders/replacement Austin Healey 1
