MK2 Brake problems
higgins
I need help with a brake problem.
A friend of mine owns a MK2 with disc brakes all around.
When you step initially on the brake pedal, it travels slowly downwards almost all the way to the floor.
Release the pedal once and it brakes fine with normal pedal travel.
We've checked everything on the car, including rebleeding, but cannot find the fault.
Please help
maynard
Sounds like the master. You can do a line check to be sure. With padded visegrips or line clamps, clamp every brake line. Step on the brakes and see what happens. The pedal should be hard. If it isn't, the master is shot. If it is, remove one clamp at a time and step on the brake and see what happens. If a caliper is bad, the pedal will drop.
jdvintage
Member
Please help
Just wondering if you solved your brake issues?
D MK2 brake puzzlement Jaguar 15
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
H MK2 lover, but... what about an E type? Jaguar 5
Sopwith_Camel linkage jag mk2 Jaguar 1
Bristol401 For Sale Jaguar Mk2 Jaguar Classifieds 2
T Spitfire MK2 Generator Triumph 3
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
T Spitfire 67 MK2 Wiring Triumph 12
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
T MK2 vs 420 values Jaguar 20
A Austin Cambridge MK2 Other British Cars 2
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
I 1961&62 Mk2 sprite roofs Spridgets 1
I 61&62 mk2 roofs Austin Healey 2
D MK2 fuel system Jaguar 1
D MK2 rear springs Jaguar 3
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
LarryK Found MK2 parts in cavern. Jaguar 3
blurooster MK2 for wife Jaguar 21
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
D MK2 front motor mounts Jaguar 0
RickB Poor little MK2 Sprite - Seattle Craigslist 'Sebring bonnet' Spridgets 24
Sopwith_Camel mk2 parts left over Jaguar 4
S My dads 1962 Mk2 Austin Healy finally seeing light since 1981. Austin Healey 4
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
Lin Check Valve for Reservac Tank - MK2 Jaguar 3
M Spitfire Spitfire MK2 calipers Triumph 4
B going to look at a 61 mk2 Jaguar 5
AN5Sprite Jag Mk2..Deal or No Deal? Jaguar 12
C What are the differences in Midget MK2 and MK3 top Spridgets 6
L Spitfire 1965 Triumph Spitfire MK2 Triumph 4
longbridgehealey top bow mk 1 and mk2 sprite Spridgets 4
6 '65 MK2...typical "whats it worth ? " post Jaguar 4
J Brakes for a Mk2 Ford Cortina Other British Cars 4
D MK2 idler arm Jaguar 6
K Door Strikers and Latches MK2 Triumph 3
D MK2 rear axle "Bump Steer" Jaguar 4
D MK2 upper radiator hose question Jaguar 3
D MK2 wiper motor Jaguar 4
D MK2 sandwich mounts Jaguar 3
D MK2 console armrest Jaguar 3
D MK2 rear shocks Jaguar 3
